ABS light mystery
Old 04-07-2010, 10:37 AM
JethroF250's Avatar
JethroF250
JethroF250 is offline
Question ABS light mystery
ok i moved to Wildwood, NJ and alot of the stores down here are higher than the streets so they have the concrete ramps goin up to the parking lot. last night i was backing out of the China House, the truck was twisted a bit from the angle i was goin and the ABS light came on. it stayed on till i got home which is like a mile away. i turned the truck off in front of the condo and restarted. the light didnt stay on so i drove round the block and still didnt come on. what could cause this to happen? thanks for any info guys
John
Old 04-07-2010, 10:51 AM
Talyn's Avatar
Talyn
Talyn is offline
Check the wiring harness that goes to the sensor on the rear diff.
if its tight someplace, or got pinched, mighta set off the light.
Old 04-07-2010, 10:55 AM
JethroF250's Avatar
JethroF250
thats what i was thinking but didnt know if the sensors would throw the light as a failure indicator. how's your 1's doin? what kind of boost you gettin
Old 04-07-2010, 01:11 PM
RRranch's Avatar
RRranch
RRranch is offline
I'd check that wire harness too. It probably just got pulled on the sensor and lost connection for a second. The ABS light will stay on till you shut it off then repeat it's check cycle when you restart it, then go out and stay out if the fault is gone. It's most likely the wire connector back on the axle.
Napa and Oreilleys have that pigtail now in case anyone needs one. It's black and white wires on it so you have to be careful about getting the right wires connected if you use it but it is pretty cheap.
Old 04-07-2010, 01:20 PM
JethroF250's Avatar
JethroF250
yea im gonna check on that. may see if i can get it through AutoZone as thats where i work now. HELLO BIG DISCOUNTS!!!! lol
Old 04-07-2010, 01:25 PM
RRranch's Avatar
RRranch
RRranch is offline
That part should be ok there but be real careful with electrical and electronic parts like alternators, starters and sensors there. I have had nothing but trouble with them over the years. It's hard for them to have the prices they do and stock well made parts. Their plug wires are the worst in the business!
Trigger1911
06-10-2023 05:07 PM
Redstroker73
01-23-2017 08:51 AM
Tburns96PSD
09-18-2016 04:29 PM
ReBilld
38
07-16-2015 06:16 PM
biederboat
Aerostar
10-19-2003 02:16 PM
Quick Reply: ABS light mystery
