Identify rear end
Old 04-03-2010, 09:10 PM
dlogan3762's Avatar
dlogan3762
dlogan3762 is offline
Identify rear end
I have been a member for a while now, and just got a 1986 F250. How do I identify the rear end?
Old 04-03-2010, 09:15 PM
BurninValves's Avatar
BurninValves
BurninValves is offline
What does the rear punkin' look like, Does ot have an cover on the back, and how many bolts holding it on. if there is no diff cover it's a 9' rear. My brothers 86 f-250 has a sterling in it. another friend has an 8.8 and another has a 9' my 86 F-150 has an 8.8 with locker. my 84 had a 9. hard to say...
Old 04-03-2010, 09:46 PM
johnboy427's Avatar
johnboy427
johnboy427 is offline
Should be a sterling 10.25, the 8.8 and 9" were the half ton rears.
-John
Old 04-03-2010, 09:57 PM
bigred86fordf250's Avatar
bigred86fordf250
bigred86fordf250 is offline
My truck is an 86 f250hd(over 8500 gvwr). It has the Sterling 10.25 rear in it. Do your hubs stick out real far with bolts around the face of the hub? if so it's most likely the sterling 10.25with full floating axles.
Old 04-03-2010, 10:19 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,725 Likes on 1,395 Posts
If it has a oil fill plug in the rear cover and the hubs stick out, it's a dana rearend.
Old 04-04-2010, 07:20 AM
SlowNSteady's Avatar
SlowNSteady
SlowNSteady is offline
the sterling is also the "10.25" ford" correct? if so thats what i have in my 88 f-250. and how do you know if your truck is an F-250 HD?
Old 04-04-2010, 12:23 PM
Franklin2's Avatar
Franklin2
If the hubs stick out the center of the rear wheels.
Old 04-04-2010, 02:01 PM
SlowNSteady
deleted cause i didnt read the whole post like an idiot.. sorry
Old 04-10-2010, 06:38 PM
dlogan3762's Avatar
dlogan3762
Thanks everyone
I just wanted to thank all of you for your help. I saw a picture of the rearend cover listed as the 12 bolt Sterling, so now I know.
D
rochhound
13
09-19-2019 10:43 PM
68fordf100v8
08-14-2012 10:51 AM
fordberg
1947 and Older Ford Trucks
07-08-2004 09:46 PM
csangster
05-04-2004 08:05 AM
arnolan
07-16-2003 12:13 AM
Quick Reply: Identify rear end
