Replacing Instrument Panel Lights &
Old 03-23-2010, 07:02 PM
Goudey's Avatar
Goudey
Goudey is offline
My 97 F 150 left side of the inst panel is dark. How to change the bulbs?
Also the glass in the left hand mirror shakes....How to tighten it up if possible?
Thanks for any info.
Richard
Old 03-23-2010, 08:20 PM
fordf150farmer's Avatar
fordf150farmer
fordf150farmer is offline
https://www.ford-trucks.com/forums/5...ng+dash+lights
here ya go for the pannel lights. its really pretty straight forward. dont just replace the big bulbs do the little ones two.... i made that mistake.. .
at least the three in the top of the speedometer.
if you find the answer for the mirror, i too am interested in the answer.
Old 03-24-2010, 09:47 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
Another pointer, when you replace the instrument cluster lights, go with LEDs. You will never have to change them again. And yes, do them all. Otherwise you can have another one go out at any time. While not the hardest job out there, it is not something you want to do again.
You just start by removing the panels in going for it. You might need a set of start drives, some of the bolts might have a torx head.
Old 03-24-2010, 01:25 PM
Goudey's Avatar
Goudey
Goudey is offline
Thanks for the info.....I don't know how to get the dash apart.....the 3 screws up under the speedo area are easy but what comes next or first? Tried prying a bit on the piece near drivers door....no luck. Any way to take the top of the dash over the speedo out? Or is it accessed by some other way?
Thanks, Goudey
Old 03-24-2010, 07:58 PM
Marty's 97 F-150's Avatar
Marty's 97 F-150
Marty's 97 F-150 is offline
Copy and paste this link
Picasa Web Albums - gregg - Gauge Lights ...
I used it when I did mine and it is step by step with pictures. Saved a lot of headaches. Hope this helps you out
Old 03-24-2010, 09:24 PM
Podaso's Avatar
Podaso
Podaso is offline
If you find answers to the mirror vibration, I need to know too...I think it's because the panel/cover (matching your paint color) on the back lets air in, but I'm not sure. I do know the panel is removable.
Old 03-24-2010, 10:20 PM
firefighter1416's Avatar
firefighter1416
firefighter1416 is offline
had the mirror vibration issue as well guys only solution i found was a whole new mirror, i tried everything to fix it.
Old 03-24-2010, 11:38 PM
Podaso's Avatar
Podaso
Podaso is offline
Do you remember how much that cost? My mirrors have the "invisible" signals in them so they're probably more than normal.
Old 03-25-2010, 07:24 PM
firefighter1416
i just kept my eyes on ebay and found a pair of used ones from a junker, i think i gave 80 for a pair of electrics with a painted cover
ligito
1999 to 2016 Super Duty
15
08-07-2016 10:06 PM
Justin73supercamper
06-03-2016 07:54 AM
mark_k
02-19-2016 01:31 AM
bf5113x
01-15-2016 04:58 PM
ydaveitsu
12-23-2015 05:43 AM
Quick Reply: Replacing Instrument Panel Lights &
