I've gotten burned a bunch of times. Often, I'd check a thread several days later and find that my posted links had been deleted. If it hasn't happened to anyone else, that's great. However, I've been burned a number of times, and therefore take measures to deal with the problem, as well as objecting to how limiting such a policy is to the scope and usefulness of the forum. YMMV, but I'm not going to change my views because someone else has successfully avoided the censors.
The video was great (and so is high speed)! I had the conception of spark and combustion being for the most part simultanteous. The video shows it isnt the case. Also the spark isnt a single event but multiple arcs over time.
I guess this is a sort of a hijack but, does anyone here have any experience using an MSD distributor on a Y-block? I keep seeing them on ebay and am tempted..........
If you will use it with points, you will need the resistor if the primary resistance is much below 3 ohms.
If you will use it with electronic ignition, read the ignition's instructions and make sure the primary resistance will work with it.
