best new gear ratio with 35s?
33"s are 32.8 inches in diameter (average)
35's are 34.6 inches in diameter (average)
37's's are 36.6 inches in diameter (average)
The Effective ratios in relation to the OEM tires are as follows:
33's:
4.10.....3.96
4.30.....4.15
4.56.....4.40
4.88.....4.71
35's:
4.10.....3.76
4.30.....3.94
4.56.....4.18
4.88.....4.48
37's:
4.10.....3.55
4.30.....3.72
4.56.....3.94
4.88.....4.22
If your tire is exactly 33, 35, or 37, then the chart looks like this:
33's:
4.10.....3.93
4.30.....4.12
4.56.....4.37
4.88.....4.68
35's:
4.10.....3.71
4.30.....3.89
4.56.....4.12
4.88.....4.41
37's:
4.10.....3.51
4.30.....3.68
4.56.....3.90
4.88.....4.17
If you have been comparing what gasser folks here and elsewhere have been regearing their axles with oversized tires, you find a lot that try to be conservative and choose too high of a ratio.
You need to think about where you want to be if you were with the original tires and wheather or not you are towing or want better mileage.
Also, remember that the larger the tire, the worse the rolling resistance, and that calls for a slightly lower ratio to overcome that.
However, with a diesel and the torque it gives, you really just need to keep your effective ratio near or just a little lower than the OEM 3.73.
Looking at the charts, that puts you, as Fatdan said, using the 4.10 or the 4.30's. For the diesel, I would go for the 4.10.s to keep the engine RPM's up near the same as the OEM rate. But, if you are going to 37's, then get the 4.56. (edit: ooops. that should have been 4.30)
33's:
4.10.....3.96
4.30.....4.15
4.56.....4.40
4.88.....4.71
35's:
4.10.....3.76
4.30.....3.94
4.56.....4.18
4.88.....4.48
37's:
4.10.....3.55
4.30.....3.72
4.56.....3.94
4.88.....4.22
33's:
4.10.....3.93
4.30.....4.12
4.56.....4.37
4.88.....4.68
35's:
4.10.....3.71
4.30.....3.89
4.56.....4.12
4.88.....4.41
37's:
4.10.....3.51
4.30.....3.68
4.56.....3.90
4.88.....4.17
As someone who has personal experience with this, if you own a diesel truck:
35s= 4.10
37s=4.30
4.10 gears will get you back your stock power and fuel economy, 4.30 gears with 35s will put you above this and your truck will run out of steam at the top. Trust me, I know this first hand...
The dicussion started here on the 4th page and it ended on page 7: https://www.ford-trucks.com/forums/6...y-caved-4.html
All in all, a very expensive lesson learned...
35s= 4.10
37s=4.30
colemanw
18
12-29-2008 04:06 PM
