1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Another question, overhead consule stopped working
Old 11-08-2010, 11:01 AM
desertPatty's Avatar
desertPatty
desertPatty is offline
The display that shows temp and direction quit. We checked fuse 10 amp #19 in the book, and it's good.
Any thoughts on how to get it working again?
Thanks!
1999 F350 4x4 dually 7.3 diesel.
Last edited by desertPatty; 11-08-2010 at 11:51 AM. Reason: forgot the year of truck
Old 11-08-2010, 11:25 AM
driximus's Avatar
driximus
driximus is offline
I would check the connections going into the overhead console.
Old 11-08-2010, 11:30 AM
clux's Avatar
clux
clux is offline
What year is it?
It's often resistors that break loose on the circuit board.
Old 11-08-2010, 11:52 AM
desertPatty
added in the year etc, sorry about that.
Old 11-08-2010, 11:57 AM
clux's Avatar
clux
clux is offline
Old 11-08-2010, 12:35 PM
desertPatty
Thank you, thank you!! Very detailed, which is what we needed!! How long did it take you to do this, being very careful? ;-) Or have you done so many that you are a rip & pull kinda guy? Will try this and see what's loose.
Old 11-08-2010, 01:13 PM
clux's Avatar
clux
clux is offline
It's a 5 minute job to remove the circuit board, but it did take me a while to do the soldering, I'm not an electronics expert by any stretch.
Old 11-08-2010, 02:30 PM
desertPatty
We just took it apart, and it looks like the label that says the # fell off, what is left is a little white rectangle. He's seeing how much the whole thing is, $408.95!!!. In the meantime he will super glue that tag on, and he pushed them all in to make sure they are snug, just need to put it back together and see if it works.
Thank you all so much!!
Old 11-08-2010, 04:38 PM
clux's Avatar
clux
clux is offline
The part that falls off is a resistor, they need to be soldered back on the board. You can replace them with Radio Shack resistors if you can't get the originals to solder down. The 620 is a 62 ohm resistor, and the 680 is 68 ohm.
Old 11-09-2010, 06:52 PM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
try finding a local electronic repair shop. they specialize in soldering jobs that are quick and easy for a pro. Usually not expensive. They may even have the resistor you need in stock. I had a guitar/amp repair shop fix mine for FREE, no parts needed, just soldering, had it back next day!!!(store was located next to the pest control office I worked at)
Old 11-09-2010, 11:21 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
EXCURSIONATOR1 is offline
I put the radio shack resistor in mine. I tried soldering mine it lasted a few months a fell off again.Resistor works perfectly. ALSO the obc doesn't cost $400. It's $165 at the local dealer.
Old 11-14-2010, 04:27 PM
desertPatty
Where for $165? Wow, we want one. My Ford dealer wants $408 plus tax! Ouch! We will take ours to a friend who is an expert electronics person, and try the resistors, as that is in budget. however, we would like to have the $165 plan B as a more positive back up plan.
Old 11-18-2010, 08:21 AM
MegK's Avatar
MegK
MegK is offline
Clux, you rock. Great pics and instruction. Took me longer to get outer cover off than to fix actual problem....only the 620 was loose on mine. Pushed gently on all of them just to be sure (used eraser end of a pencil ) Plugged back in and came right on. Thanks!
Old 11-18-2010, 10:46 AM
Going_Going_Gone's Avatar
Going_Going_Gone
Going_Going_Gone is offline
There is a place on ebay that sells reconditioned circuit boards for around $30 plus refundable core charge on your old one.
kupaa
08-19-2010 10:51 AM
bang4dabuck
17
02-03-2009 11:03 PM
big john
1983 - 2012 Ranger & B-Series
01-09-2003 07:38 AM
flyingsheep
10-13-2002 11:33 PM
ogre316
Exhaust Systems
07-05-2001 10:17 PM
Quick Reply: Another question, overhead consule stopped working
