ROUSHCharger Help
ROUSHCharger Help
So I recently installed a non-intercooled RoushCharger on my 04. When I received my PCM back from Roush, I put it in and started it. It started fine, but the Check Engine light came on and I got the codes for why the light is on. I have the P0011 and P0021 codes and also P0340 code (I think). Also, it seems that the truck isn't getting full boost. Maybe vacuum lines? Or Boost Bypass might not be hooked up right? Any advice would be helpful!
Thanks
Thanks
I'm told the stock Roush tune is very much on the conservative side. You could very well have a vaccum leak though. Did you go over the instal from top to bottom to make sure everything was done right? Did you do it yourself, or did you take it somewhere to have it done?
on
First let me say I don't have a Roush charger in my truck. But the codes you list are all VCT/Cam codes.
P0011 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
Here's a link for this code Code P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0021 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
Link Code P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0340 - Camshaft Position Sensor Circuit Malfuntion
Link http://www.obd-codes.com/p0340
A code P0340 could mean one or more of the following has happened:
- a wire or connector in the circuit could be grounded/shorted/broken
- the camshaft position sensor may have failed
- the PCM may have failed
- there exists an open circuit
- a crankshaft positon sensor has failed
- Visually inspect all the wiring and connectors in the circuit
- Check for continuity in the circuit wiring
- Check the operation (voltage) of the camshaft position sensor
- Replace the camshaft position sensor as required
- Check the crankshaft position circuit as well
- Replace circuit wiring and/or connectors as required
- Diagnose/replace the PCM as required
Tylus
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
17
02-22-2009 07:26 PM
FTE Ken
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
01-30-2008 12:29 PM
