rear axle replacement
I skided into the ditch the other day on black ice and busted the rear wheel off. I have a 99 Ranger 4x4 with I believe a 3.73 limited slip diff. My question is should I just look for a replacement axle or should I replace the entire rear end, and if so since I will be looking for used parts what vehicles used this same rear end? I have been told that if the rear end has taken a hit bad enough to bust an axle than it should be replaced, but maybe rebuilding is an option???? Not sure what to do at this point???
Thanks
Thanks
Brian it may be cheaper to find the whole rear axle in the salvage yard and swap out than rebuild. If there is any damage inside or that shows up latter such as bearing or teeth whining it could get expensive. I just got a quote of 5 hrs labor just to install LS in my Ranger. That is right at $350 labor with me buying the LS unit.
I vote too that you replace the whole axle with a used one from a scrapyard. Look around for one out of a '93+ Ranger that:
a) has a 4.0L engine, and/or
b) is a supercab.
This will ensure you get the 8.8"/28 spine version that you need.
Also, because it's a 4x4, it's important that you confirm the gear ratio because you need to swap in an axle with the same ratio.
b) is a supercab.
cdichiar
15
06-30-2014 10:53 PM
farmert
06-03-2013 11:24 AM
