Theft light and running rough
Old 02-14-2010, 02:15 AM
dropper's Avatar
dropper
dropper is offline
I can't figure this one out.
Truck is running rough usually at acceleration.
The weird thing is the theft light blinks when it is running rough.
Any ideas?
2001 4.2
Old 02-14-2010, 02:36 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
The Theft function normally would have nothing to do with 'dynamic' engine performance because the PATS system is a way to 'enable' the PCM function only and not have any effect on the PCM's normal functions. This is the Theft protection.
The roughness is a second issue.
The only possible way for both to be affected at the same time is an electrical issue common to both such as the ignition switch or PCM power relay.
The flashing Theft lamp could have a dash code associated with it that may give a tech a clue what to look at.
Dash codes have thier own procedure for read out on the dash speedo. Unless you have the codes and procedure, it is of little value at the moment.
Good luck.
rickebowdle
1999 to 2016 Super Duty
16
09-21-2021 07:11 PM
wrathchild
Escape & Escape Hybrid
06-07-2017 05:17 PM
tristyan89
1997-2006 Expedition & Navigator
11-10-2015 08:47 AM
Hossfly05
07-03-2015 04:06 PM
Rustyiron55
1983 - 2012 Ranger & B-Series
06-28-2015 06:11 AM
Quick Reply: Theft light and running rough
