01 ranger anti theft bypass?
Did you you try to start it without a PATS key, or with the key in the ignition, or the ignition on, or perform some under dash work without first disconnecting the battery???? Maybe have a look through this info a member posted http://www.scribd.com/doc/11145204/P...C-Service-Tips
If you have, or can come by an ELM scantool, download & run the latest version of FORScan & post All trouble code Number clues it finds, or if it finds PATS has been triggered, see if the latest version of FORScan with PATS programming will reset it.
More thoughts for consideration, let us know how it goes.
Carl........
1983 - 2012 Ranger & B-Series
11-16-1999 05:17 PM
