Why does my 6.0 Excursion smoke!!!!!
Old 02-02-2010, 04:16 PM
ddubbs79's Avatar
ddubbs79
ddubbs79 is offline
Smile Why does my 6.0 Excursion smoke!!!!!
I have a 2004 Excursion with a 6.0 diesel.. The thing will sometimes smoke alot when it is idling . Not diesel smoke either! It is all oil-blue. Someone told me this could b egr related or turbo??????? It doesnt do this all the tiome sometimes it'll go a month without doin it. Somebody give me sum insight! Thanks
Old 02-02-2010, 05:04 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is online now
Retired Mod
Blue smoke almost always suggests an issue with the injectors....
I had the same thing happen to me three times during the winter of '06, my truck would loose power, start coughing up bluish white smoke, and idle really rough. I thought that I'd lost an injector or two, but the problem was the lack of lubrication in the fuel system. It seems the station I'd been filling up at had a particularly dry load of ULSD. I had stopped using Diesel Kleen every tank like I used to and it caught up with me. I started using it again, it cleared up the problem, and it hasn't happened since.
With that in mind, 6.0s aren't like 7.3s and require much more love and attention. If you're not already running synthetic (5w40) that would be something to consider at your next oil change. Per my recommendation, I'd dump a full dose of the silver bottle in, fill up, and take it for a cruise on the freeway. If that doesn't clear things up, it may be a more serious problem.
I'll move this down to the 6.0 section to get you a more in-depth answer...
Old 02-02-2010, 05:13 PM
ddubbs79's Avatar
ddubbs79
ddubbs79 is offline
Thank you much
realjag
04-26-2015 08:51 PM
Engalwood
1999 to 2016 Super Duty
04-20-2015 01:18 PM
fabsroman
04-20-2015 05:03 AM
fluidp
11-06-2013 11:01 AM
maxwellt
06-05-2011 03:14 PM
Quick Reply: Why does my 6.0 Excursion smoke!!!!!
