bue smoke ??
Old Nov 5, 2013 | 05:10 PM
fluidp's Avatar
fluidp
bue smoke ??
hi All,
Im getting blue smoke upon acceleration Any Ideas??
06 f350 6.0
Thanks
Old Nov 5, 2013 | 07:36 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Blue smoke is usually oil. Turbo seal is a common failer. You can pull down pipe on the back of the turbo and check for oil "swirl" inside the pipe. Could also be blow by on rings/valve guides and valve seals. Pull oil filler cap and watch smoke coming from crankcase. A little bit is common but if it smokes like a freight train it's likely blow by. It's possible on a high mileage motor to get a lot of oil in the intercooler and large connecting tubes, cleaning that out may help for a while.
Old Nov 5, 2013 | 08:53 PM
fluidp's Avatar
fluidp
I just did stc fitting, stand pipes, dummies, drove ror about 40 miles after that and now back in shop doing the injector seals and O-rings,
When I pulled the inlet off the turbo, there was a small collection of oil at the turbo inlet.
Turbo was installed by ford 25k ago, maybe bad seal in turbo??
The truck has 160,000miles on it. always did oil and filters befor due, I have oil rails off and valve train looks clean as a whistle.
I guess a compression check would tell if I have a bad hole??
Old Nov 6, 2013 | 08:37 AM
Rusty Axlerod
I think turbo seal commonly leaks to the outlet side of the turbo. Compression test is a good idea if you suspect piston rings but doesn't tell you much about valve guides. Leak down test works better if you have the equiptment. Several threads lately on that subject.
Watching how much smoke comes out of the oil filler cap gives a good general idea of how much blow by you have.
There could be a problem with crankcase vent and you have a lot of oil in the intake tubes and intercooler. There isn't a drain on the intercooler, you'll have to pull it and pour it out to check.
Old Nov 6, 2013 | 11:01 AM
fluidp's Avatar
fluidp
Thank Rusty.,
After I get my injectors back in I will fire up and check the blow by...
Is there any benefits to switching to a Full Syn Motor oil, 0w40, or 0w30 ??
Pastor Jared Parmley
Jun 8, 2019 10:34 AM
DDPJ
Sep 4, 2017 09:54 PM
joeyd61
Mar 12, 2012 11:59 PM
olbattlebuggy
May 14, 2011 04:03 PM
spitball
May 28, 2004 08:20 PM
