HELP with BW4407
HELP with BW4407
I just bought a 1996 F-250 and can't seem to find a 4lo or neutral. I can pull the shifter down once and it will engage into 4x4, but the shifter won't pull down any further and that's 4hi. The shifter is missing the *** so i can't find the shifting pattern and after googling, I can't find much info on the 4407 at all. Does anyone know if it even came with a 4lo? Any help is appreciated.
Bradley
Bradley
BW 4407? Never heard of that one. You should have a BW 1356 in your truck.
The shift pattern is, from front to back: 2HI - 4HI - N - 4LO
You don't need to push down, but there is a slight indent going from 4HI to N. You have to push it a little to the left. If it doesn't go in, make sure the transmission is in neutral (not park), you aren't moving at all, and there is no tension or binding in the driveline. If it still won't go then you probably have some rusty linkage. Try to work it free with some PB blaster and keep it lubed with white lithium spray grease.
FoxClubNiner
09-28-2017 05:54 PM
Pheadrus
17
04-06-2014 09:52 AM
USMC0351fordtruckin
04-17-2011 06:35 PM
93f1505.0L
01-18-2010 08:23 AM
