HELP with BW4407
Old Feb 19, 2010 | 09:59 PM
strokinout's Avatar
strokinout
HELP with BW4407
I just bought a 1996 F-250 and can't seem to find a 4lo or neutral. I can pull the shifter down once and it will engage into 4x4, but the shifter won't pull down any further and that's 4hi. The shifter is missing the *** so i can't find the shifting pattern and after googling, I can't find much info on the 4407 at all. Does anyone know if it even came with a 4lo? Any help is appreciated.
Bradley
Old Feb 20, 2010 | 12:41 PM
Lazy K's Avatar
Lazy K
Not sure about yours but on some you have to push hard down on the lever before pulling back to get 4lo.
Old Feb 20, 2010 | 01:56 PM
Ford_Six's Avatar
Ford_Six
I went on a little internet hunt and yes you need to push the shifter down then pull back.
Old Feb 24, 2010 | 02:13 PM
strokinout's Avatar
strokinout
I'm sorry about getting back to this so late. I just went out and gave it a shot. I can't thank you enough. I just couldn't find any info except for places for rebuild kits with google. Do you know what range it has or if it's even a good transfer case?
Bradley
Old Feb 24, 2010 | 02:34 PM
andym's Avatar
andym
BW 4407? Never heard of that one. You should have a BW 1356 in your truck.
The shift pattern is, from front to back: 2HI - 4HI - N - 4LO
You don't need to push down, but there is a slight indent going from 4HI to N. You have to push it a little to the left. If it doesn't go in, make sure the transmission is in neutral (not park), you aren't moving at all, and there is no tension or binding in the driveline. If it still won't go then you probably have some rusty linkage. Try to work it free with some PB blaster and keep it lubed with white lithium spray grease.
Old Feb 24, 2010 | 04:30 PM
Ford_Six's Avatar
Ford_Six
4407 was used with the PSD before the Super Duty. Much stouter case, bigger chain, etc.
Low range is 2.69 IIRC, it also has six pinions vs the four of the 1356.
There were two different linkages- 96 is the push down one, 97-98 is not.
Old Feb 24, 2010 | 04:47 PM
andym's Avatar
andym
Huh... learn something new everyday. Thanks Jared!
Old Feb 24, 2010 | 07:35 PM
strokinout's Avatar
strokinout
I found out it was a 4407 from the tag. It's a massive transfer case. Ford_Six, can you think any reason why I would have one? I don't have a Powerstroke.
Old Feb 24, 2010 | 07:53 PM
Ford_Six's Avatar
Ford_Six
It was used behind 460s in F350s, maybe it was an option?
FoxClubNiner
Sep 28, 2017 05:54 PM
Pheadrus
17
Apr 6, 2014 09:52 AM
USMC0351fordtruckin
Apr 17, 2011 06:35 PM
93f1505.0L
Jan 18, 2010 08:23 AM
OBS96
Dec 5, 2009 07:29 PM
