2005 F150 Airbag Module??
Can someone please tell me where this thing is located. I am sick of this airbag light being on! It blinks 5 times and then just stays on after start up. I have tried disconnecting the battery for 5 min.(did not work)
I found one from a salvage yard and I am thinking about ordering it...
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Are you sure the light only blinks 5 times? Fords usually will blink a # of times then pause and then the light will blink a different # of times and pause again. It will repeat this sequece a couple of times before the light stays on. The two light blinking sequenses make up the code. For ex. if the light blinks 4 times, pauses, then blinks 6 times. The the problem code will be "46".
Here I got a better answer...
33 Restraint System - Safety Belt Pretensioner Fault (Driver Pretensioner Circuit Fault)
Read more: http://www.justanswer.com/questions/...#ixzz0c5DmHj8F
Cool, thanks alot man!! This gives me a good starting point. Tomorrow when it's not cold as shyte outside I will check to see if there are any loose connections under the drivers seat....
on
PM me if you would like a .pdf copy from the Ford Repair manual to troubleshoot this problem...
on
Code 42 is fairly common. I did a search in this forum and found this... Click on the link below...
https://www.ford-trucks.com/forums/5...bag-codes.html
Check out post #3
Check out post #3
dasanders123
18
05-21-2009 09:26 PM
