1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Self Alignment?
Old 01-06-2010, 08:54 AM
jdunbar's Avatar
jdunbar
jdunbar is offline
Self Alignment?
Just replaced all ball joints and tie rod ends on my 2004 F250 4x4 Diesel. I measured and set toe in the same as before. It's about an 1/8 inch toe in. I centered the steering wheel as well. Question is...do i spend the money for a front end alignment? All they can do is set toe in and align steering wheel right? Caster and camber look good (all new upper and lower greasable ball joints). Does my toe in sound right? Thanks!
Old 01-06-2010, 11:22 AM
06silvercrew's Avatar
06silvercrew
06silvercrew is offline
NONONONO!!! You need to get a proper alignment. For tire wear and drive.
No they can set toe, center steering wheel, adjust caster and camber unsing an ecentric bushing in the upper joints.
Old 09-16-2012, 08:37 AM
chef dr's Avatar
chef dr
chef dr is offline
where do i purchase an ecentric bushing
Old 09-16-2012, 11:19 AM
parkland's Avatar
parkland
parkland is offline
lol i love the randomness of this.
Old 09-16-2012, 11:32 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,584 Likes on 1,061 Posts
Either a Ford dealer or any auto parts store.
Old 09-16-2012, 11:43 AM
schmidt64's Avatar
schmidt64
schmidt64 is offline
You cannot do a proper alignment at home
Old 09-16-2012, 12:15 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
since you messed with the ball joints, I really suggest you get a proper alignment. that can throw off all 3 parameters. you will start eating front tires if the other 2 aren't correct.
true
but I know for a fact that you can do an alignment at home that'll get extremely close so she'll track straight with no abnormal tire wear...using a tape measure. but I'll only do that when I replace tie rods. If I mess with ball joints then I'll visit a shop
Old 09-16-2012, 02:38 PM
ak-angler's Avatar
ak-angler
ak-angler is offline
Originally Posted by Tylus
...since you messed with the ball joints, I really suggest you get a proper alignment...
Why? There are NO adjustments at the ball joints, unless you count the castor/camber bushing, which isn't actually adjustable. It's indexed so you need to actually replace it to change either the castor or camber.
Now, there's nothing wrong with checking that everything is the way it's supposed to be. But if it needs any adjustments, it's not because somebody "messed with the ball joints".
Old 09-16-2012, 05:10 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Yup, you can do an alignment at home. I've seem me do it. This was on my old Explorer using some jackstands, fishing line and a metal rule. It was darn close.
Old 09-16-2012, 06:24 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
that's your call
at $300-400 per tire, I will gladly go spend $80 and get an alignment done to prevent cupping of tires. especially if they're like new
Old 09-16-2012, 08:20 PM
ak-angler's Avatar
ak-angler
If you want to throw away $80, you can always just send it to me.
Onesprint
11-27-2017 10:07 PM
BioBurner
08-02-2017 01:51 PM
bruno2
16
02-14-2012 12:36 PM
dlash74
29
05-26-2010 09:08 PM
StangVT66
1983 - 2012 Ranger & B-Series
06-12-2007 11:02 AM
Quick Reply: Self Alignment?
