5-20 or 5-30 motoroil?
Okay, I've heard both. Someone sale me on one or the other please.
I have a 99- F250LD 4x4 with the 5.4 triton w/ 200,000 miles. Seeing as
how I live in Georgia and it's 18 degrees right now I'm leaning to the
Motorcraft 5w-20w blend. With a FL 820s motorcraft filter. Then, when
it warms up in March or April, go with the 5w-30w. Someone change my
mind . With good info.
thanks
thanks
5w-20 would be just fine year round. There is no need to go to a thicker oil. 5w-30 though is so similar that you will not notice the difference. Buy which ever is cheaper.
These motors need oil to get to the heads as quick as possible on start up. Which is why a thicker oil is not preferred. These are not old pushrod beasts of past which needed thicker oil.
FWIW I have over 200k on mine using only Motorcraft or Castrol GTX 5w-20 and Motorcraft FL-820s filters.
Ambient temperature and resistance to flow are inversely related. This means, the colder the temperature drops, the higher the resistance to flow of oil. Changing from 5W-20 to 5W-30 for an advantage in winter therefore doesnt make sense. A change from 10W-30 to 5W-30 in the winter would make sense because, at cold temperature, the 5W has LESS resistance to flow and can reach vital engine parts faster on cold startup.
If the manufacturer calls for 5W-20 then use it.
2 problems with using the heavier oil. One, increased oil drag, you may read higher pressure, but you get reduced oil flow to the critical parts like bearings. The oil will run hotter and break down more quickly, resulting in increased chemical wear. Two, you will get lower fuel economy, not by much, but it is measurable.
Stick with 5w20, your engine is designed for it. You mileage is irrelevant, even if it had half a million miles I would still run 5w20.
Tom Evans
07-28-2017 11:15 PM
A_Freebird
Oil & Lubrication
13
01-04-2016 09:00 AM
