Key ignition won't stop "dinging"!!
Hey guys,
After I pull the keys out of the ignition and open the door, the chime comes on thinking I've still got the key in. I've got to fiddle around and wiggle the **** out of the ignition and sometimes it'll stop
I was reading in another thread that there's a ball bearing to tell if the key is in or not? Could that ball bearing be sticking?
Is it going to hurt to spray some WD40 in there and see if that frees up the ball bearing? If not I'll open up the steering column
My guess is the plastic clip that holds the dinger in place broke. If you remove the bottom half of the steering column cover you should be able to see the wire and either tape up the end of it so it doesn't ding anymore or try to glue it back together.
Many of us cut the wire to disable the dinger. Just make sure you've got a spare key handy until you get used to no dinger.
Just fyi, "tearing the steering column apart" only consists of three phillips screws and a button to pull out the ignition switch.
It's easy to fix, thankfully. I have been thinking about killing mine, because when i'm working on the truck I like to have the stereo on, but don't want the glow plugs and fuel pump running at all, so i turn the key back to the accessory position, and if you leave the door open it never stops dinging..... ugh...
on
Read post 3
I did this a long time ago for other reasons, like leaving the radio on while the doors are open
https://www.ford-trucks.com/forums/8...-ignition.html
Sadly, killing the black wire w/ pink tracer won't kill the chime in the ACCESSORY position. Been there, done that. You have to remove the chime in the GEM to fully disable it. There is a write up on this, but I haven't bothered to do it. I rarely use ACCESSORY right now. Read this https://www.ford-trucks.com/forums/3...y-quiet-7.html Post # 105
Oh well. Thanks for the info.
how do you disable the dinger to were it does not work at all? will cutting the blue and gray wire as said in the thread do it?
https://www.ford-trucks.com/forums/82...-ignition.html
Kwikkordead
141
04-26-2020 07:10 AM
itsnotavan
08-08-2017 04:03 PM
Torgmada
1983 - 2012 Ranger & B-Series
08-19-2011 01:56 AM
