flywheel change rfc
Old 03-19-2000, 09:09 PM
Abbey's Avatar
Abbey
Abbey is offline
flywheel change rfc
Im going to change my flywheel sometime soon.
If anyone has any tips, advice, tricks Id
appreciate it if you shared them with me.
(specifically, Ill be working on a 77 f100
with a 302 and C4...and the why for this
project is that the ring gear has come off
the flywheel -- and lodged itself against the
trans bellhousing -- and I thing the flywheel
may be warped.)
Thanks....Abbey
Old 03-20-2000, 12:32 AM
BigBrownTruck's Avatar
BigBrownTruck
BigBrownTruck is offline
flywheel change rfc
I call your part a flexplate (on an automatic) and a flywheel on a manual. You need to get a replacement flexplate w/ the proper counterweight for your 302. Unless you have a 81 and up 5.0 then you use a 28.2oz counterweighted flexplate/flywheel. I believe that you may use a 351W,351C flexplate if you find, one as well as the pre 81 302, maybe 289,255 (doublecheck on that). The other part that needs to be right is the diameter or the flexplate/ringgear. I believe the truck bellhousing uses a 164tooth ring gear. If you had a warped flexplate, did it destroy the thrust bearing in you engine? Something most suspiciosly a bad tranny destroyed the thrust in a 302 I had. I was able to grab my harmonic balancer and pull the crank back and forth within the block. If your thrust is gone, bad news. The endplay on the crank shouldn't be more than .010".
good luck
BBT
Old 03-20-2000, 10:13 AM
Ford390's Avatar
Ford390
Ford390 is offline
flywheel change rfc
69 f-100 aman
WTB - Ford Trucks & other vehicles
12-23-2012 05:18 PM
Russ250 fx4
Virginia Chapter
12-15-2012 11:37 AM
rsm1012
07-12-2007 12:12 PM
foggy_2
04-25-2002 02:42 AM
Abbey
03-02-2000 04:56 AM
Quick Reply: flywheel change rfc
