Axel codes
A9 = Spicer-Dana 60.3 Rear Axle / 3.54-1 / LIMITED SLIP / 3300 lb. Rear Axle Capacity.
1961/67 F100: When Limited Slip was ordered, Ford usually installed the Spicer-Dana 44 because the 9" was not available in F100's with Limited Slip (until 1968).
In addition, the Spicer-Dana 60.2 (1961/65) or Dana 60.3 (1966/72) with or without Limited Slip were also available as options.
Thanks Bill. What is the difference between the Dana 60.3 and the 44? The 9" is also a limited slip, so it must be a replacement rear end.
Prostock, all my other trucks had 9" so I've not had any experiance with Danas. Anybody else have any thoughts? The Dana is in a parts truck I have and the 9" is in a driver.
Chas1234
02-16-2003 02:12 AM
