Dana 60 oil rear axle
Old 12-11-2009, 06:18 AM
bartuitschaijk's Avatar
bartuitschaijk
bartuitschaijk is offline
What type of oil should I put in my Dana 60 rear axle? It is not a limited slip. 80w90? Does it make a difference if I use synthetic or not?
It's for my 73 F-250 with 8100GVWR.
Thanks,
Bart
ps how many liters/quarts do I need?
Old 12-11-2009, 11:32 AM
zak8tac's Avatar
zak8tac
zak8tac is offline
I believe it holds 3 quarts. I use synthetic 80w-90 in mine. Just make sure you park level and fill it up until it is level with the fill hole. Some people will park it down hill and "overfill" it, this is detrimental and will build excess heat so do not do that.
Old 12-11-2009, 12:18 PM
1979camperspecial's Avatar
1979camperspecial
1979camperspecial is offline
yup 3 quartz or six pints or 3/4 of a gallon. In this cold weather it is going to take forever to pump in. I like to jack the truck up really high on one side and remove an axle shaft then pour six pints down the tube.
Old 12-11-2009, 12:25 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
I won't even ask how you change your motor oil lol.
The following users liked this post:
Old 12-11-2009, 12:30 PM
1979camperspecial
LOL. I do that normal......I know the procedure is a little weird but I have done this enough in winter weather to know you can save about a an hour pouring it in over hand pumping it. that 90w is thick at these temperatures. In fact I just did it last week
Old 12-11-2009, 12:37 PM
bartuitschaijk
Thanks,
Removing the shaft seems like a lot of work to me to, why don't you just warm up the oil in its cannister before you pump it in?
Bart
ps synthetic or regular, does that make a difference, except for the price?
Old 12-11-2009, 01:28 PM
1979camperspecial
Originally Posted by bartuitschaijk
Thanks,
Bart
I have nothing to warm a five gallon bucket of gear oil with, and I would be killed if i brought it in the house.
I would be willing to bet I can remove a axle and pour it in faster than you could pump it in by hand. It's really not that hard to pull a shaft and since I do a lot of towing of a 10,000lb trailer, i like to inspect them occasionally.
I run regular in mine. But I'm cheap. I would imagine that the synthetic is better, as it probably has better heat resistance/protection.
Old 12-11-2009, 02:43 PM
zak8tac's Avatar
zak8tac
zak8tac is offline
synthetic vs. regular. Well I've just replaced all of my gear oil from regular to synthetic, I can tell you I notice it in the tranny and transfer case because it shifts much easier in the cold. I have not had any increase in mpg, I have not had any increase in "leakyness" lol and I will never go back to regular gear oil. I'm certain it helps during cold weather lubrication as it flows a little easier. Plus the synthetic doesn't smell as bad either.
Old 12-11-2009, 02:45 PM
zak8tac's Avatar
zak8tac
zak8tac is offline
hahahahaha roflmao
Old 12-11-2009, 06:10 PM
jdv19's Avatar
jdv19
jdv19 is offline
I just replaced all my fluids in both my front and rear axles, tranny and transfer case. Used Lucas synthetic 80-90 in everything. I notice a big differance in the easy of shifting as well.
Dirtyweekender77
11-10-2013 07:51 PM
79fordf250pickup
03-12-2012 06:17 PM
kilich
04-01-2011 08:11 PM
adam83
09-01-2009 06:14 PM
Chubby
Offroad & 4x4
10-04-1999 04:27 PM
Quick Reply: Dana 60 oil rear axle
