Dana 60 oil rear axle
What type of oil should I put in my Dana 60 rear axle? It is not a limited slip. 80w90? Does it make a difference if I use synthetic or not?
It's for my 73 F-250 with 8100GVWR. Thanks, Bart ps how many liters/quarts do I need? |
I believe it holds 3 quarts. I use synthetic 80w-90 in mine. Just make sure you park level and fill it up until it is level with the fill hole. Some people will park it down hill and "overfill" it, this is detrimental and will build excess heat so do not do that.
yup 3 quartz or six pints or 3/4 of a gallon. In this cold weather it is going to take forever to pump in. I like to jack the truck up really high on one side and remove an axle shaft then pour six pints down the tube.
Originally Posted by 1979camperspecial
(Post 8229594)
Originally Posted by montana_highboy
(Post 8229611)
I won't even ask how you change your motor oil lol.
Thanks,
Removing the shaft seems like a lot of work to me to, why don't you just warm up the oil in its cannister before you pump it in? Bart ps synthetic or regular, does that make a difference, except for the price? |
Originally Posted by bartuitschaijk
(Post 8229658)
Thanks,
Removing the shaft seems like a lot of work to me to, why don't you just warm up the oil in its cannister before you pump it in? Bart ps synthetic or regular, does that make a difference, except for the price? I would be willing to bet I can remove a axle and pour it in faster than you could pump it in by hand. It's really not that hard to pull a shaft and since I do a lot of towing of a 10,000lb trailer, i like to inspect them occasionally. I run regular in mine. But I'm cheap. I would imagine that the synthetic is better, as it probably has better heat resistance/protection. |
synthetic vs. regular. Well I've just replaced all of my gear oil from regular to synthetic, I can tell you I notice it in the tranny and transfer case because it shifts much easier in the cold. I have not had any increase in mpg, I have not had any increase in "leakyness" lol and I will never go back to regular gear oil. I'm certain it helps during cold weather lubrication as it flows a little easier. Plus the synthetic doesn't smell as bad either.
(Post 8229611)
hahahahaha roflmao |
I just replaced all my fluids in both my front and rear axles, tranny and transfer case. Used Lucas synthetic 80-90 in everything. I notice a big differance in the easy of shifting as well.
