7.3 glow plug controller install issue
Actually it does, my WTS light is on for a second or two then goes out and the clicking starts. Not for long though.... [Going to degrease and clean up the engine in case I need to post a pic with a question.....]
Well, I got it figured out.
I ended up getting another controller as a parts warranty (we'll let ford figure that one out). Don't really know if it was the controller or moving the ground, but she's back together and doing what it should. WTS light comes on, then I get the clicking after the appropriate delay.
As for the ground tab (which may or may not have been the real issue). I moved it to UNDER the control unit. It was hooked up to a wiring harness hold-down bolt. I had even cleaned the area before reattaching to that spot. This time I put it under the driver side mounting bolt for the control unit.
So, it was either a bad control unit out of the box, or relocating the ground. either way, I'm back on the road when it's cold out, without having to look for a place to plug in an extension cord...
As long as the bolt was grounded the location should make no difference.
Was the bolt you used the first time on the engine or on the firewall?
I ask because if it was the firewall, that could indicate a cab grounding problem.
But it does sound like a defective new part right out of the box.
Electrical............
I have added grounds from both of my battery negative terminals to the body.
Also added an extra engine block to cab ground.
Also added an extra engine block to frame ground.
And I ran a wire from the battery back to my trailer plug to supply a direct ground to what ever I tow.
Yes it was a little excessive, but the grounding straps Ford installed so many years ago do fail.
I have the same issue i went down to my local parts store and picked up a new GP controller/relay and when i go to turn the key my WTS like goes on for 2 seconds and then off and then it starts clicking like on and off on and off i hooked it up right am wondering if i have a bad ground since the controller is moved over to the passenger side valve cover because of the after market turbo system or is it a bad controller should i return it and get a new one? up were i live am scared of shutting it off and going some where for an hour or two and having it not start.
Yeah, that.
The controller reads the resistance to ground through the glow plugs to determine how long to glow. The glow plugs resistance goes up with temperature, and the controller reads this. If a couple plugs are burned out, the resistance that the controller sees is high, and the controller thinks the engine is warmer than it really is...
I had 2 bad plugs, and my WTS light came on for about 3 seconds in 20º temps with a cold engine...
justaworktruck
10-14-2016 04:20 PM
Ryanmeff19
07-03-2016 08:33 PM
Forddiesel17
16
03-20-2016 08:08 PM
CaptainFacePunch
13
08-13-2015 03:38 PM
