shake when taking off
01 f350 4dr shrt bed 6spd
my truck shakes pretty violently when taking off, seems to be worse with the trailer,
if i let off the clutch really fast it doesnt really shake, but i cant always do that.
any ideas
all steering, shocks, ball joints, rear leafs replaced within last 60days or so.
i also have a south bend clutch, about 8-10 monthes old , prolly has 40-50k on it
any ideas
shake when taking off...
I just had my clutch replaced this week on my 1999 7.3. The same thing was happening. I also noticed a scraping noise coming from the transmission if I had to hit the brakes hard. Found out a couple bolts were missing from the transmission housing. The clutch definitely needed replacing. I also had a leak from the rear seal. No more shaking.
The starter sounds much better when engaging.
When I had the work done, the mechanic also told me there was a type of linkage that ties in with the turbo that had come disconnected. I have noticed it's been a year since the turbo wouldn't kick in like it used to.
They put in the heaviest clutch available and I notice a huge difference putting the clutch to the floor now. I think it was a matter of time before something else would have happened.
But the shaking was very frustrating. It didn't matter if I was towing or not.
I see you replaced your rear leafs, did it raise the rear of the truck any? When I put an add-a-leaf in the rear of mine I had the same shake when taking off, I shimmed the carrier bearing 1/2 inch and it went away. I am assuming your truck has a carrier bearing though. Just a thought, greasing the splined shaft may help also.
FordBoy2012
05-20-2015 06:47 PM
supercabfreak
23
09-24-2010 10:27 PM
