I am Lost Help Please no crank no start
what i have is a 03 6.0 F350 4X4
my son and I went to deer lease I have a 3500 inverter we forgot and left on, gto a jump and everything workrd great 2 days later i cranked the truck pulled out drive way it died like you turned key off, i tryed to start nothing punt in nutral still same. i turned lights on they never dimmed while turning key to start traced wires found (everything works on truck)power wire to key switch traced power through switch all good to fuse pannell. traced power wire to starter i took 12 volts to wire motor turns over went back to fuse pannell found start power going in but not to starter, a friend told me the fuse pannells tend to go bad i bought new one same thing so i had both batters check they checked low and were four years old so i replaced both, I need help bad
TSB 06-19-14
Dave
one more try
Dave
that is what i thought i tested it from power coming in and throught it. i started with main power to switch check all leads and start wire to fuse pannell is green i should get 12 volts out at starter wire witch is yellow with blue stripe and i dont, even with new fuse pannell. it seems like there is a safty like nutral safty holding out crank circuit or some other safty holding it out??
thanks for your help Dave!!!!
Once you have drained your batteries, just driving it will not properly recharge them. If you did not quickly put them on a charger after the deer lease trip, then you could easily have damaged your FICM (Fuel Injection Control Module) due to low system voltages. There are quite a few recent threads on checking it and repairing it (if needed).
There is also a troubleshooting guide on "no starts" in the Tech Folder.
I looked a my prints for a 2003 and it shows that there is a starter relay inside the central junction box that has to come in before you get power to the starter motor. Also there is a couple of fuses that can be checked. F2.113 and F2.31, both are located in the central junction box. I would use a meter and check to make sure that there is power on both sides of these fuses when the ignition is in the start position. I would also check the relay to see if it is coming in when the ignition is in the start position.
Nealva
12-19-2014 06:27 PM
BrandonT71
08-02-2013 07:52 PM
2littleant2
1997-2006 Expedition & Navigator
18
05-26-2013 06:18 PM
diesel-fitter-bum01
18
04-19-2010 01:00 AM
