Issue with starting - need ideas
Old 07-08-2012, 03:56 PM
Central Texcursion's Avatar
Central Texcursion
Central Texcursion is offline
I was having to jump the truck most times, although I wasn't driving it much. Pulled the batteries, there were from 2008 (I didn't know, I bought the truck used) so I pulled the alternator as well and went to Auto Zone for testing. All failed, so out the door $400 lighter. Installed the new batteries and alternator, went to crank - nothing. No click-click of a not-quite-enough-juice battery, just nothing. When the key is in the accessories on position, there is a rapid electrical clicking noise - it wa doing that with the old batteries and now the new. Leave it in the accessories on positiion and it eventually stops. But before it would turn over, now it won't. Hooked up scan gauge and it said No Response.
Uh oh? I didn't try tapping the starter yet I guess.
Old 07-08-2012, 04:18 PM
Shepherd2's Avatar
Shepherd2
Shepherd2 is offline
Have you checked the ignition switch? Sounds like it's not getting or putting out 12V.
Old 07-08-2012, 05:28 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Turn on your headlights and see if they go on?
Also check the interior dome lights, I suspect they all go out/blink
along with that noise because that's the symptom of a weak battery
or connection.
I suspect you don't have a good connection @ the new battery(s).
Old 07-08-2012, 05:31 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Yep, bad battery cable or connection.
Old 07-08-2012, 07:03 PM
Central Texcursion
Well, interior lights do come on as do dag indicators when in the accessory on position, but when tuning the key further to crank the engine there is no click or half turnover - nothing. I am not familiar with the double battery wiring - completely in series? Or is one for cranking and the other for accessory type stuff?
Old 07-08-2012, 08:29 PM
Central Texcursion
Lights come on. Ignition fuse fine but replace anyway. Everything works but if train all te way - nothing. Sucks because I have to be somewhere.
Where is the starter
Old 07-08-2012, 08:46 PM
Central Texcursion
Found the starter - no luck withthe tap
Damnit
Old 07-10-2012, 07:34 AM
Central Texcursion
Turned out to be a theft code, I guess that was tripped because I pulled both batteries? What is frustrating is I have a scangauge II and it showed nothing, but when hooked up to someone's laptop running scantool it showed the theft code and could be cleared.
It was very frustrating. Is there something unique about my truck or does everyone's theft code get set when both batteries are pulled?
Old 07-10-2012, 09:55 AM
LWW's Avatar
LWW
LWW is offline
I haven't ever pulled both batteries but I'm surprised your Scangauge II wasn't able to clear the code. I wonder if you just told it to clear all codes if it would work even though it wouldn't display it?
Even though my Banks IQ also has standard "code reader" capability, I'm happier every day since I bought the AutoEnginuity from RiffRaff...
MTP55
48
01-19-2017 05:08 PM
Caldwell F150
04-18-2012 07:24 AM
ozarksF250
1999 to 2016 Super Duty
09-01-2011 09:50 PM
Barndon
16
01-12-2010 09:14 PM
Kinville
1983 - 2012 Ranger & B-Series
04-01-2006 10:10 PM
Quick Reply: Issue with starting - need ideas
