Oasis
Is this report still available? Do I need to follow another process? I had never even heard of an OASIS report until I joined this board - seems like a good report to have. The person I purchased my 2000 Excursion from was selling it for his recently divorced parents, and he had no records of any maintenance. I believe the appropriate routine maintenance was completed because I did see dates and milleage written on various components that require scheduled replacement. However, it would be great to see if there were any major issues or repairs. I know they used it to tow a trailor home back and forth to Georgia.
If there is a specific process I needed to follow in order to obtain the report please let me know. Thanks.
https://secure.carfax.com/showme.cfx
you can get 1 free carfax report right now. don't know how long this link will last.
Report Applies to Country Code: USA
OASIS RESULT:
1FMNU41S8YEE49860
USA
EN
09/24/2009
06:31:56
FCXWS447
© Copyright 2002-2009 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2000 EXCURSION BODY STYLE
XLT 4 DR WAGON 4X4 ENGINE
6.8L EFI SOHC
TRANSMISSION
4R100 (E4OD) 4SP O/D AXLE CODE
ENGINE CALIBRATION
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/15/2001 BUILD DATE
06/27/2000 SALE MILEAGE
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
NO RECENT REPAIR HISTORY ON VEHICLE
Click Here for Full Warranty History
| On-line 1878
END OF OASIS REPORT FOR 1FMNU41S8YEE49860
OASIS RESULT:
1FMNU41S8YEE49860
USA
EN
09/24/2009
06:31:56
FCXWS447
VEHICLE INFORMATION
VEHICLE DESCRIPTION
6.8L EFI SOHC
TRANSMISSION
ENGINE CALIBRATION
ARN MESSAGES
WARRANTY START DATE
EXTENDED COVERAGES
| On-line 1878
Standard Claims List For Model Year 2000
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 0 7S02 180102 * 14401 * L25 B4 8
AWS Claim Key: 5853170 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 00235 - * Name: STARKE FORD-MERCURY, INC. Ph: 904-9647200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2001 Doc #:18043203
Cust Comments: RUNNING BOARD LIGHTS WILL NOT GO OFF
Tech Comments: CK DOOR AJAR PIDS WITH NGS AND RUN BCE SELF TEST, ALL PIDS OK FOUND REAR DOOR SWITCH LOOSE R AND R REAR DOOR PANEL,
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 0 5V88 000615 * NPF * H05 82 8
AWS Claim Key: 5853171 Trx Code: 1 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 00235 - * Name: STARKE FORD-MERCURY, INC. Ph: 904-9647200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2001 Doc #:18043202
Cust Comments: BRAKE PEDAL VERY HARD DOES NOT STOP WELL
Tech Comments: BRAKES WORKING WITHIN MANUF STDS AT THIS TIME
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 0 1F03 030304 * 8287 * E29 01 8
AWS Claim Key: 7235303 Trx Code: 1 Labor Hrs: 1.5
Dlr Cd-Sub Cd: 00235 - * Name: STARKE FORD-MERCURY, INC. Ph: 904-9647200 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:16-JAN-2001 Doc #:18043201
Cust Comments: CK ENGINE LIGHT ON, TEMP GUAGE PEGGED OUT
Tech Comments: TEST EEC, KOEO PASS P1290 P1285 P1299, MONITORED PIDS OK OVER TEMP CONDITION NO COOLANT IN RADIATOR, ALL HOSE CLAMPS
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 5 * * * * * * * 4201
AWS Claim Key: 11050058 Trx Code: 01S24 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 00937 - * Name: RONNIE BURNS FORD INC Ph: 864-4612237 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:29-AUG-2001 Doc #:06885452
Cust Comments: RECALL 01S24
Tech Comments: RECALL 01S24
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 5 1G02 03XXXX YC3Z 8501 AA E23 D1 4201
AWS Claim Key: 11050057 Trx Code: 2 Labor Hrs: 1.9
Dlr Cd-Sub Cd: 00937 - * Name: RONNIE BURNS FORD INC Ph: 864-4612237 St:SC Ctry Cd: USA Reg Cd: NA Repr Date:29-AUG-2001 Doc #:06885451
Cust Comments: CHECK COOLANT LEAKING ONTO GROUND FROM ENGINE AREA
Tech Comments: FAILED SEAL COOLING SYSTEM PRESSURE TEST DIAGNOSIS
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 5 1G02 03XXXX YC3Z 8501 AA L85 D1 4989
AWS Claim Key: 11065039 Trx Code: 2 Labor Hrs: 1
Dlr Cd-Sub Cd: 03898 - * Name: COGGIN DELAND FORD Ph: 386-7751000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:07-SEP-2001 Doc #:039646A
Cust Comments: COOLANT LEAK FROM WATER PUMP AREA (HAS NEW WATER PUMP)
Tech Comments: PRESSURE TEST COOLING SYSTEM AND REPLACE WATER PUMP
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 17 2G04 000615 * DIAG * E29 82 14124
AWS Claim Key: 17838737 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 03898 - * Name: COGGIN DELAND FORD Ph: 386-7751000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-SEP-2002 Doc #:064675A
Cust Comments: E29 C S CK ENG LIGHT IS ON LACK OF POWER
Tech Comments: RUN ENGINE DIAG, RECORD WITH WDS, CHECK PID MONITER RECORD AND DTC P1285 P1299 CYLINDER HEAD TEMP OVER TEMP
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 17 1G02 03XXXX YC3Z 8501 AB L87 D8 14124
AWS Claim Key: 17838738 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 03898 - * Name: COGGIN DELAND FORD Ph: 386-7751000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:03-SEP-2002 Doc #:064675B
Cust Comments: L87 C S COOLANT WAS 1.5 GALLONS LOW IN RADIATOR
Tech Comments: PRESSURE TEST SYSTEM AND REPLACE WATER PUMP AND BLEED AIR FROM SYSTEM
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 21 1G02 030305 YC3Z 8501 AB L87 D1 18826
AWS Claim Key: 19097946 Trx Code: E84 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 03898 - * Name: COGGIN DELAND FORD Ph: 386-7751000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:13-DEC-2002 Doc #:071486A
Cust Comments: L87 C S TRK IS LEAKING COOLANT FOR THE 3RD TIME SEE STEVE
Tech Comments: ROAD TEST COOLANT LEAK, PRESSURE TEST AND REPLACE WATER PUMPAND FLUSH SYSTEM. CORRISION FOUND ON PUMP BLADES. ADD COOLANT ADDITIVE FOR PH FAILURE PURGE AREA AND RETEST
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 37 1G02 03XXXX YC3Z 8501 AB L87 D8 40185
AWS Claim Key: 22723918 Trx Code: P05 Labor Hrs: 1
Dlr Cd-Sub Cd: 03898 - * Name: COGGIN DELAND FORD Ph: 386-7751000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:20-APR-2004 Doc #:106010A
Cust Comments: L87 C S COOLANT IS LEAKING, WATER PUMP HAS BEEB REPLACED. SEE SSMS ATTACHED
Tech Comments: PRESSURE TESTED SYSTEM REPLACE WATER PUMP
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 37 5K06 * * * * * * 40189
AWS Claim Key: 22731429 Trx Code: 04B14 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 03898 - * Name: COGGIN DELAND FORD Ph: 386-7751000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:22-APR-2004 Doc #:106193A
Cust Comments: 04B14 FRIRSTONE TIRE RECALL
Tech Comments: INSPECTED ALL FIVE TIRES AND REPLACE FIVE TIRES UNDER THEPROVISINS OF THE PROGRAM
1FMNU41S8YEE49860 T/L1 F T/WD T/CA T/E A1 T/DE T/WA 27-JUN-2000 15-APR-2001 124403 USA 66 * * * * * * * 63685
AWS Claim Key: 25470944 Trx Code: 05S28 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 03898 - * Name: COGGIN DELAND FORD Ph: 386-7751000 St:FL Ctry Cd: USA Reg Cd: NA Repr Date:28-AUG-2006 Doc #:167161A
Cust Comments: RECALL#05S28
Tech Comments: INSTALL JUMPER HARNESS PER RECALL
