Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 09-10-2009, 09:14 AM
sphinx's Avatar
sphinx sphinx is offline
Garage is empty, add now
sphinx is starting off with a positive reputation.
V10 fuel pressure?
Any body changed a fuel pressure regulator on one of these? I'm having an issue with it running really lean, like laying down with no power lean.I put the pressure gauge on it and I'm running an even 30 pounds at the rail. Changed the filter in hopes, but no change.
Just changed the O2 sensors and they were both white.
  #2 (permalink)
Old 09-10-2009, 11:38 AM
brownie83's Avatar
brownie83 brownie83 is offline
brownie83 has a very good reputation on FTE.brownie83 has a very good reputation on FTE.brownie83 has a very good reputation on FTE.
i had the exact same thing...i had to replace the fuel pump...ended up having sugar in my tank...but, make sure u test the pressure while driving. mine had 30 at idle, but driving it only had like 15...strap the gauge to the wiper and watch it. probably a fuel pump problem...good luck
__________________
Chris -200K+ Club Member
2000 F250 CC 6 Spd 7.3 POWERSTOKE MODS:(Thanks Jim) BRIAN'S TUNES,AIH Delete,.50 Mod,Fog Lights,6637 aFe Filter,4" MBRP Turbo Back and Dual Stacks,GRP LED,ProComp 9000 Shocks,EBPV/Pedestal Delete,CCV Mod,Glowshift 3 in 1 & Fuel Press. Gauges,Foil Delete,IDM Mod,RR Frx,RR Hrx,In-Tank Mods,6.0 IC, RR boots and inserts,MidWest Short Shifter,910 Springs,Melling LPOP,Van Turbo,Joey's T500,ATS Housing*1999 Polaris 455 DIESEL
  #3 (permalink)
Old 09-10-2009, 02:06 PM
sphinx's Avatar
Guess I should have taken a test drive before posting. Changing the O2 sensors straightened the problem out. Go figure, I knew that they could go bad and not throw codes, but had never had one fail on me like this before.
Out of curiousity I ran it with the fuel pressure gauge hooked up, It stuck constant on thirty, I even tried pressing the pressure relief vavle on the side of the gauge and it didn't even stumble, pressure dropped to 20 and then bounced right back up to 30.
Now if I can trace down my itermittent miss I'll be set. I have the feeling that the plugs are original, judging from everthing else I've fixed so far.
  #4 (permalink)
Old 09-11-2009, 08:15 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
You should get about 38-40 with the vacuum disconnected from the regulator.
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see. ®
Tags
10, 2003, 2006, check, excursion, f250, ford, fuel, holding, ideal, pressure, regulator, sensor, specs, test, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
