P0354 Code What next
My 99 F150 5.4 is setting the p0354 code. I have replaced the Coil, Spark plug, Fuel injector and it hasn't seemd to make a difference. Where should I go form here? I was going to do a compression test to see whats up. Any suggestions? I checked the wiring and I didn't see any abrasions. I hooked an old coil and spark plug, started the engine and it seems to be firing okay. What should the compression reading be? Can an internal problem cause the p0354 code to set?
Since this code refers to the coil primary circuit, it shouldn't be mechanical issue.
I looke around a little and they discuss it in some detail here.
https://www.ford-trucks.com/forums/6...ode-p0354.html
Note, the post with the most info seems to require you to have html or whatever turned on -- or else just ignore all of the
</td></tr> <tr> <td style="border-right: medium none kind of stuff
Good Luck,
hj
Good Luck,
hj
Let me shorten this a bit for you.
Code 354 is cylinder 4 open coil primary circuit.
Check that you have 12 volts to ground at the one lead on the plug.
If yes, use a VOM meter set to resistance to read 10,000 ohms.
On the other lead test for about 10,000 ohms to ground looking back at the computer.
If you see very low or very high resisitance, the solid state switch is faulty in the computer.
If this should be the case, the computer has to be replaced.
It is a dealer job. They will have to get a unit based on the original ID.
They will go online to a FORD data base with your VIN to access your original build data.
This allows a copy of the original program to be down loaded for flashing the new computer.
If PATS is involved, you need 2 keys to complete the job.
Hopefully it's not the computer.
Good luck.
Good luck.
oss150svt
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
11-14-2010 10:28 PM
