OBDII codes , misfire
Old Dec 16, 2016 | 02:57 AM
roughridn_sob's Avatar
roughridn_sob
While Im sure there are a million threads for codes on here I wanna try and narrow down the problem and be specific
My wife was driving her truck yesterday and said the MIL light started to flash and the truck felt like "it was about to blow up" . So when I got home I busted out the trusty old scanner and this is what I got:
P0305- Cyl 5 misfire'
P0354- Ignition coil D primary/ Secondary circuit malfunction
P0304- Cylinbder 4 misfire
The truck is a 2005 5.4 with ~130,000 on it and it runs very well for the most part. I have done the spark plugs before the summer and replaced them with the motorcrasft sp-515s. Im guessing the problem will be with the #4&5 coil packs. is there a way to troubleshoot these?
Old Dec 16, 2016 | 02:51 PM
pdqford's Avatar
pdqford
Shade tree way is to swap the #5 coil with #6,
and the #5 spark plug with #7, and drive it to
see if the DTC changes.
Old Dec 17, 2016 | 07:51 AM
projectSHO89's Avatar
projectSHO89
Focus on #4 first. Of course, it's the hardest to get to.
Old Dec 18, 2016 | 05:27 PM
roughridn_sob
NEW INFO:
So without troubleshooting further I just went ahead and changed the number 4&5 COPs. Truck seemed to be running well, until we just took a 2 hour trip up to the airport. Truck started to shake again and MIL came back on, I had brought the scanner with me and attached a picture of the new codes. Additionally I noticed the the truck has a stutter or hesitation at mid-throttle letting off or giving a little more pedal will smooth it back out.
Old Dec 18, 2016 | 05:34 PM
martyf150's Avatar
martyf150
Take a look at your Catalytic Converter i had the same problem on my 07 and that's what it was it was clogged up. There is a back pressure test that can be done on them. I was told by the dealer that it should read 1-2 psi my was 18-20 psi.
Old Dec 18, 2016 | 07:05 PM
roughridn_sob
thanks Ill check that out
afmedic
May 23, 2016 07:55 PM
busflyer
Modular V8 (4.6L, 5.4L)
Nov 19, 2013 04:12 PM
Estam
Feb 9, 2012 11:08 AM
homer1972
1997 - 2003 F150
Nov 21, 2007 09:37 PM
fireman649
Oct 15, 2004 06:22 PM
