Service engine light no codes runs rough 7.3
Old 08-13-2009, 04:25 PM
dougx75's Avatar
dougx75
dougx75 is offline
What will set on the SES light. AFTER IT CAME ON the engine started to run rough until about 2000 rpm. It even shakes a little at idle. No codes. Any help appreciated............... It is a F250 2001 7.3
Old 08-13-2009, 04:59 PM
fifthwheel01's Avatar
fifthwheel01
fifthwheel01 is offline
UVCH loose?,
Did you hear a loud POP before it happened? Could be a loose intake boot.
Might need to check the Icp sensor connection.
Maybe the EVBP sensor and tube.
Just suggestions.
Old 08-13-2009, 06:10 PM
triskit16's Avatar
triskit16
triskit16 is offline
No codes? I thought the codes were stored until cleared by user?
Id bet on UVCH as well...
Old 08-13-2009, 07:10 PM
F350-6's Avatar
F350-6
F350-6 is offline
If the SES light came on, there are codes stored in the PCM. It sounds like your scanner can't see the codes. The free scans at the parts stores can't read our codes either.
More info would be helpful, but UVCH sounds like a good guess at this point.
Old 08-13-2009, 07:13 PM
Donny_D's Avatar
Donny_D
Donny_D is offline
i think o'reilys can read them... none of the other ones can though... it cost ~99bucks at ford to get the codes read at dealership...almost worth getting an AE if your truck breaks alot lol
Old 08-14-2009, 12:10 AM
orng1's Avatar
orng1
orng1 is offline
If there is a light there are codes.
Old 08-14-2009, 09:31 AM
agg_bagg's Avatar
agg_bagg
agg_bagg is offline
yep and i would bet on the UVCH also.
Old 08-14-2009, 12:28 PM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
I also agree... you will have to remove the valve covers and fix the loose connector...
See the following thread link for all the info..:
https://www.ford-trucks.com/forums/8...ck-shakes.html
clintbonnie
oops.. double post...
Old 08-16-2009, 07:23 PM
dougx75's Avatar
dougx75
dougx75 is offline
Problem found, Thanks for all the replys. I tried to get codes with my $30 scanner but nothing. Went to a friend with a scanner that cost thousands. It allows to chatter the injectors to see if they are operating. Low and behold #5 is sticking. He is seeing more and more problems with the new fuel formulation which has had the luibricating properties removed. He suggests 4 oz of 2 stroke oil per 20 gallons in fuel. Or, a product meant to lube injectors. Never tranny fluid, it has a seal expander and can damage the injector.
starvingartist55
08-23-2016 10:48 PM
1996_powerstroke
10-21-2015 07:34 PM
RFJjr
09-26-2015 11:15 AM
mrk28645
01-07-2013 05:34 PM
schrock42
10-08-2011 08:16 PM
Quick Reply: Service engine light no codes runs rough 7.3
