Lowered my 09'
#31
Thanks for the suggestions. I'll check out the F-150 RBs to see how similar they are to the Sport Trac's, which work fine for us. FoMoCo keeps getting rid of good stuff like A-pillar grip assists, drat it! Bummer.
In years past one could usually spec out smaller diameter wheels/tires on an F-150 and lose a couple of inches of height (shades of the F-100) but I suppose that avenue's unavailable now due to disk brake caliper assembly clearances, etc.
Thanks again for the response.
That said, a lowered pickup WILL absolutely handle better if you have matched spring rates front and back...look at the NASCAR trucks--they run pretty low. In the old days, you could actually reach over the sides of the bed and load/unload things without needing a ladder. Seems like today's trucks are designed to be intimidating for those people who need to "wear" a tall and macho vehicle. I hate the look of a foot of air above the rear tires where you see the inside sides of the bed and stuff.
If you are offroading, you need high ground clearance... On the street, not so much.
George
#32
Maybe this is a dumb question but if you carry handicappers around, might you consider something like a van or minivan instead of a pickup? That said, a lowered pickup WILL absolutely handle better if you have matched spring rates front and back...look at the NASCAR trucks--they run pretty low. In the old days, you could actually reach over the sides of the bed and load/unload things without needing a ladder. Seems like today's trucks are designed to be intimidating for those people who need to "wear" a tall and macho vehicle. I hate the look of a foot of air above the rear tires where you see the inside sides of the bed and stuff. If you are offroading, you need high ground clearance... On the street, not so much.
George
George
Thanks, too, for the matching spring rate tip. No off-roading intended.
#33
I installed the 2" lowering shackles soon after buying my truck. No difference I can tell in ride or handling. Truck looks a whole lot better w/o the rear sticking up. That's my individual preference, and I'm sticking to it! I have been very pleased with my truck with no problems save the slip yoke TSB (which worked on my truck).
33,000 miles and rollling.
MikePacey
41
09-28-2015 02:48 PM
'78f350
04-17-2014 06:28 PM
