Change 292 to 312
Old 07-12-2009, 09:16 PM
brandon1078's Avatar
brandon1078
brandon1078 is offline
Change 292 to 312
I have a 60 Ford p/u with a 292. Could someone tell me what the difference is between the 292 and 312? I know that it's the same block...I was thinking it was just the heads and crank. Can someone tell me what I need to do to turn my 292 into a 312?
Brandon
Old 07-12-2009, 09:21 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
the 292 and 312 are the same exact engine just different stroke cranks and journal size is how I understand it. maybe slightly larger bore but I have seen people push a 292 out to 312 cid.
Old 07-12-2009, 10:50 PM
Rocketman55's Avatar
Rocketman55
Rocketman55 is offline
Lots of good info on Y-blocks here: http://www.y-blocksforever.com/
Old 07-13-2009, 02:51 AM
55 f350's Avatar
55 f350
55 f350 is offline
same block diff bore and stroke . just get the crank rods and pistons for a 312 and have a go at it .
Old 07-13-2009, 05:37 AM
Walston's Avatar
Walston
Walston is offline
You obviously can do what you want, but keep in mind that parts for a 312 are much harder to come by and are more expensive, you might consider just renewing the 292. By the time you put +0.040 or +0.060 pistons in, it will be over 300 cu in anyway.
Food for though.
Old 07-13-2009, 05:58 AM
conrad55's Avatar
conrad55
conrad55 is offline
Another option is to have John Mummurt build you a stroker kit for the 292 up to 338. See this site for more info.
http://www.ford-y-block.com/yblockpage.htm
Old 07-13-2009, 12:34 PM
brandon1078
Food for though.
Thanks a lot. After reading up on the 292...I think that's what I will do.
Old 07-13-2009, 06:46 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
Another thing is the 292`s didnt have the same problem as the 312 which is why you cant find many. They are very prone to fractures on the main cap webbings with the larger journal size. The 292`s didnt have that since they had more "meat" there. But the 292`s I have seen can be done up great. Same as the 312, guy on youtube has a 312 that he punched out to like 340 cubic inches but I dont know hes the same guy that told me never to run synthetic oil in a old Y block cause it wears everything evenly and these old y`s like to have valve train wear unevenly is how I take it.
jerryst
09-12-2016 11:58 AM
Nighthawk756
05-14-2012 07:38 AM
al37ford
10-19-2006 05:48 AM
Customcab
01-13-2004 11:41 AM
Nathan
06-05-2000 07:59 AM
Quick Reply: Change 292 to 312
