Voltage at coil but no spark at plug
Old 07-07-2009, 10:13 PM
Travsuw's Avatar
Travsuw
Travsuw is offline
76' F-250 4wd 390
Had the truck running fine until today, cranks just fine but won't fire at all. I've got 12V at the coil and at the end of the plug wire running from the coil to the distributor cap. When i pull a plug out and try to see a spark out of it I get nothing. I also don't think its the ignition because I'm alone and when i try and start it to look at the plug I have to turn it to run and jump it at the solenoid. I also don't have a test light. What do you think I should check using the multi-meter I have?
-Thanks
Old 07-07-2009, 11:10 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
Sounds like the pickup coil or ignition module, fmc should be around shortly to tell you how to check.
Old 07-07-2009, 11:18 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Clarify this part a little more... you have voltage to the coil, that part is clear, but you state you have voltage coming out of the coil at the post as well?
How did you check that?
Now, to substitute the DMM for the test light, turn the DMM to DC volts, hook your positive to the TACH side of the coil and the negative to ground. Now try and start the engine, the DMM should pulse between 0 and 12 telling you whether the module and pick-up are good or bad.
Also in the meantime you can test for OHMS on the distributor leads, the wires should be orange and purple and the scale is 500-800 ohms.
Post back the results.
Josh
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
It's a little hard to do by yourself without a test light, but if you have alligator clips for your multimeter, you can do it. Set your meter to read DC volts. With the coil connected, connect the multimeter between the TACH TEST terminal of the coil horseshoe connector and engine ground (clean unpainted metal on the block). Use the key to crank the motor over, and the meter should flash between 12 volts and zero.
This is equivalent to connecting a test light in place of the multimeter and watching for it to blink. If your multimeter doesn't have clips, you're going to have to have a friend crank the engine over from the cab while you hold the meter in place. To do this test, you have to use the key to crank the engine over. You can't jump it at the solenoid because you need the ignition switch to power the ignition module for this test.
EDIT: looks like Josh and I posted at the same time.
Old 07-07-2009, 11:19 PM
Bullitt390's Avatar
Bullitt390
Also, look inside the distributor and see what the condition of the rotor is. Any moisture in there will cause havoc as well.
EDIT: Dang, we posted at the exact same time!
Josh
Old 07-07-2009, 11:28 PM
Travsuw's Avatar
Travsuw
Travsuw is offline
It actually ended up being a loose connection on the coil bracket. Thanks to anyone who looked at this
Old 07-07-2009, 11:36 PM
Bullitt390's Avatar
Bullitt390
??? what was hooked-up to the bracket?
Josh
Old 07-08-2009, 01:34 AM
montana_highboy
I'm assuming he's refering to the horseshoe connector and not the actual mounting bracket
Old 07-08-2009, 08:53 AM
Tees77f150's Avatar
Tees77f150
Tees77f150 is offline
That would be my guess to, hey great explanation you two!
PS: Was going to give you both rep points, but it says I have to spread them around first.
I feel if you deserve them you should get them!!
hussite
07-24-2017 01:26 AM
IllWill
1983 - 2012 Ranger & B-Series
16
10-15-2016 09:39 PM
jermill_08
43
01-23-2016 06:13 PM
exidor12
09-13-2015 06:34 AM
BJG V10
1999 to 2016 Super Duty
07-12-2011 06:31 AM
Quick Reply: Voltage at coil but no spark at plug
