Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-29-2009, 11:24 PM
heatwave heatwave is offline
heatwave is starting off with a positive reputation.
Oil Leak near filter
I have a 1998 F150 XLT with a 4.6, V8 with 171000 miles. I have noticed under the engine on the left side or oil filter side it's wet with engine oil, every time I change oil I use an engine cleaner to wash it off. It doesn't drip on the ground , but it looks kind of sloppy after about a 1000 or more miles. It's not the oil filter leaking, it's the mount on the bottom side of the engine where the filter mounts.
Does these engines have an oil cooler? The mount looks aluminum. How hard or easy is it to repair?
Thanks in advance.....
  #2 (permalink)
Old 06-30-2009, 01:48 AM
dragon wagon dragon wagon is offline
dragon wagon is starting off with a positive reputation.
Sometimes the oil filter's rubber gasket stays on the filter houseing when its removed!! Placeing another filter with its gasket on top will cause a leak!!
Chris
  #3 (permalink)
Old 06-30-2009, 08:31 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
Sounds like the gasket between oil filter housing and engine block.
__________________
ASE MASTER TECH FORD SENIOR MASTER TECH
  #4 (permalink)
Old 06-30-2009, 08:33 AM
Joe Finn's Avatar
Joe Finn Joe Finn is online now
Joe Finn is starting off with a positive reputation.
Is your filter mounted up near the driver's side wheel well with hoses going back to the engine?
__________________
'97 F150 4x4 XLT 4.6L 3.55 LS Supercab
  #5 (permalink)
Old 07-01-2009, 03:58 PM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a good reputation on FTE. 1ATony has a good reputation on FTE.
Shouldn't be to hard to fix,not sure what seals may be in there.
__________________
Tony
1A Auto Parts
1-866-403-3393
Ford Truck Parts
  #6 (permalink)
Old 07-02-2009, 01:14 AM
ford2go's Avatar
ford2go ford2go is offline
ford2go has a good reputation on FTE. ford2go has a good reputation on FTE. ford2go has a good reputation on FTE.
It is probably NOT a gasket from an old filter that got left in there. When that happens, they usually spew oil out in pretty short order. ( Dealer did it to me once).
Might be that you're not getting the filter tightened correctly. Do you coat the rubber gasket on the filter with oil before you put the new filter on?
It just might be normal for them to leak a tiny bit.
It could be slithering down from above that spot somehow.
I assume that you're checking your oil level to be sure, but it doesn't sound like it's anthing to worry about. The only thing that I see that could a problem would be if there was a tiny crack in the oil filter mount. That could get worse over time.
I gather that you find the oil spot pretty annoying, but there might not be much that you can do about it.
__________________
ford2go (hj)
Wish I had -- F150 I6 5 speed
Have E350 RV
  #7 (permalink)
Old 07-18-2009, 04:34 PM
I thought it was the oil pan leaking at first, with air blowing the oil. By looking at the oil filter bracket, it looks like a water jacket is there. That's the reason I brought up oil cooler up. The bottom radiator hose joints to the bracket and the motor mount, mounts to it and the oil filter. It does have bolt, so I know it's not part of the block.
Has anyone here ever disassembled or rebuilt one of these engines. They would know?
Thanks
  #8 (permalink)
Old 07-18-2009, 11:43 PM
SSG VA BEACH's Avatar
SSG VA BEACH SSG VA BEACH is offline
Virginia (beach) Chapter
1999 Ford F-150
SSG VA BEACH is starting off with a positive reputation.
I had a coolant leak from that area...here is a picture from a junk eng and the gasket from ford with pt #
I was concerned when I had the problem because as you can see you have oil and water inlets and outlets on the same gasket. they said this gasket is the same for 4.6 Romeo and Windsor
__________________
ERIC
99 F150 XLT 4.6 Super Cab Flare Side
Virginia Chapter-Join! http://www.ford-trucks.com/forums/81...a-chapter.html
PICS http://www.schmidtservicegroup.com/f...husiastva.html
  #9 (permalink)
Old 07-19-2009, 11:21 PM
On my 1998 XLT, 4.6 looks different from the picture shown. Where's the oil filter located on your truck?
On my truck the oil filter is located on the left rear part of the engine. The bracket is about the length of the engine. Starting from the filter, then next the motor mount bolts to it and then in the front the the bottom radiator hose connect to it.
I'm going to study it a little more. With air blowing it , its really hard to see where it coming from. It starts right behind the power steering pump, pump being on the bottom, front of the bracket. BTW, it's motor oil, not power steering fluid.
Thanks for the help.
  #10 (permalink)
Old 07-19-2009, 11:54 PM
1999 Ford F-150
On my 99 4.6 the filter is on the front drivers side of the engine like the pic. This is the first 4.6 I have had so I am not up on all the diffs.
__________________
ERIC
Tags
2002 , 46 , engine , f150 , f250 , filter , ford , hose , housing , leak , leaking , leaks , oil , romeo , spot
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
