oil level question
oil level question
My manual says I need 4.5 quarts with filter for an oil change. Will I hurt anything if I just put in 5 quarts during my oil/filter change. Truck is a '00 Ranger with the 2.5L. 4.5 quarts takes it right to the top of the full mark.
On another note, when I bought this truck it came with a K&N air filter. I'm not a real big fan of them. What does everyone think about the Fram toughgaurd air filters?
Dont get the toughgaurd air filter. Its pre oiled and any oiled filter will get your MAF sensor dirty. I had to clean mine twice before I decided to just toss the toughgaurd filter.
Had to pull the codes and go thorough all that just to figure out it was the airfilter.....
A paper fram or whatever is the best.
Thanks for the replies. I know it's trivial, but the reason I asked is to keep from storing a 1/2 quart in the limited garage space I have. I've been prefilling the filter with 1/2 quart, then filling the engine with the other 4. After letting the truck sit for several hours, I'll check the oil. comes right at the full mark. I promise, I'll be safe and use the 4.5 quarts that's recommended
I've seen an adapter last time I was on the rangerstation web site that allowed you to put the oil filter on at an angle instead of sideways. Also allows the use of the FL1A filter instead of the 400S.
I was surprised that Walmart charges the same price for a Fram toughguard and the standard paper filter. I think I'll get the paper one to help prevent the MAF from getting dirty.
