1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 F-250 SP Powerstroke 6.0l Turbo ?
Old 04-21-2009, 05:58 PM
rblyll's Avatar
rblyll
rblyll is offline
I have a 04 F-250 SD with the Powerstroke 6.0l diesel. I just started to hear a squeal when the truck starts. I thought it might be the serpentine belt but that is fine. I just started to occasionally experience what i thought was the tranny slipping at about 60mph. However just had the tranny flushed and everything seemed OK. The mechanic thought it could possibly be my turbo sticking ? Is this a common problem ? Does this sound like a turbo issue? As well is removing and replacing the turbo an easy process?
Old 04-21-2009, 06:03 PM
12ozd's Avatar
12ozd
12ozd is offline
Turbo "sticking" is not unheard of in that truck.
Replacing the turbo is not hateful but not alot of fun.
Doubt you have a turbo that is making noise only at start up.
Old 04-21-2009, 06:06 PM
rblyll's Avatar
rblyll
rblyll is offline
it only squeals for a second on start up. I was thinking it could be a vane or something rubbing on start up. Once the motor is warm and i restart i dont get the squeal. Do you have any other ideas on what it could be making the squeal?
Old 04-21-2009, 08:58 PM
riggz's Avatar
riggz
riggz is offline
it could still be the belt. if your vanes were sticking you would notice while driving down the road with the engine under a load. it would occasionally shudder for a second and spit out some black smoke.
Old 04-21-2009, 10:41 PM
cmc's Avatar
cmc
cmc is offline
I just replaced the turbo in my 2006 6.0L King Ranch huge pain in the *** but once it is done you feel pretty satisfied. What ever you do keep in mind bigger is not alwase better. make sure you really research your turbo before you buy.
Old 04-21-2009, 10:51 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
Belt tensioner weak?
Idler pulley or idler bearing?
A turbo aint squeeking only at startup and if it does, catastrophic failure is not far behind. A vane touching the shaft at 100,000 RPM is going to do some damage and make some serious noise....
Old 04-22-2009, 01:21 PM
12ozd's Avatar
12ozd
12ozd is offline
Remove the belt and start the truck.
If the noise is gone,look at the driven accessories.
Common for idler and tensioner bearings to fail.
Also could be water pump,alternator, etc.
If you still have noise after removing the belt,You got some looking to do.
Old 04-23-2009, 01:25 PM
Wash1331's Avatar
Wash1331
Wash1331 is offline
The turbo "will" make a chirp during start up as it is the vanes moving into the idle position. My turbo has done this since I first received it and 48K with no damage or problems. It only chirps for a fraction of a second and then goes away. If it gets louder have it checked out otherwise don't worry with it.
tmill28
17
02-02-2022 04:41 PM
1993idi
04-15-2015 09:31 AM
RRTREE
6.7L Power Stroke Diesel
08-17-2014 09:56 PM
x15
04-21-2011 09:25 PM
figurhead
06-04-2009 12:56 AM
Quick Reply: 2004 F-250 SP Powerstroke 6.0l Turbo ?
