1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
how to remove 3rd row Speaker
Old 04-07-2009, 02:37 AM
pitmanr2003's Avatar
pitmanr2003
pitmanr2003 is offline
I have a 97 eb that has a blown speaker in the rear where the 3rd row seat is. i tried popping pannel off with no luck. How do you remove it so that i can unplug it till i get new speaker and what size speaker is it and are there any suggestions on what to replace it with.
Old 04-07-2009, 04:56 AM
c_hohensee's Avatar
c_hohensee
c_hohensee is offline
If this speaker is in the side wall, this is the sub-woofer speaker. The only way to unplug this is to unplug the amp. This means removing the trim panel to get to it. The enclosure will need to be removed to replace the speaker as there is a bolt on the back of the enclosure holding the speaker in. For replacement I believe there are several companies making a replacement speaker, check e-bay.
Old 04-07-2009, 02:11 PM
pitmanr2003
is that the whole trim pannel around the back area where cargo net hooks on. do you just pop it off or are there screws. are there any visual right ups on this?
Old 04-08-2009, 04:14 AM
c_hohensee's Avatar
c_hohensee
I am not aware of any write-ups. Yes it is the trim panel that runs from the end gate to the back door. It is not that bad I have had mine out a few times as I replaced my sub with a whole new after-market enclosure with new amp. The biggest pain is taking the seat belt anchors loose so you can get the panels off, both the top and bottom on the mid row seat(the top one uses a hex nut and the bottom uses a torx) and the third row uses a torx for the top and there is a small hole you push a screw driver or something into to release the bottom anchor. After taking the seat belts loose you pull the trim off from in front and back of the back side window (it just pops off). Unscrew the roundish part that the cargo net attaches too. Pull the threshold strip up below the end gate as well as the panel above the back window, there may be some screws that are hidden by the afore mentioned trim panels if so you need to remove them. About mid point under the back side window you will find a ear of the panel under the carpet that you will need to remove the push pin from. The trim panel them pulls up and away from the side wall.
Old 04-08-2009, 07:13 AM
Freak4Ford's Avatar
Freak4Ford
Freak4Ford is offline
On the 98 I used to own, I believe the subwoofer is a 8" speaker.
Old 04-08-2009, 01:54 PM
pitmanr2003
sounds like alot of work. may have to do it on the weekend. i found a write up by mtx and that sounded about like what you said. I figured there was an easier way but i guess not. I have to take 3rd row seat out as well.
Old 04-09-2009, 07:46 AM
johnpvb's Avatar
johnpvb
johnpvb is offline
Check out this thread from a couple years ago so see if there's any helpful info. I ended up replacing mine with an MTX speaker when the dealer couldn't find an OEM replacement.
https://www.ford-trucks.com/forums/3...ment-help.html
Old 04-10-2009, 03:01 PM
freeman666's Avatar
freeman666
freeman666 is offline
If it's the sub try this for instructions to remove panels.
http://www.mtx.com/caraudio/products...orms/FEN10.pdf
Old 04-14-2009, 01:31 PM
Greenscobie86's Avatar
Greenscobie86
Greenscobie86 is offline
LOL... Hey I started that thread! Never though someone would like to my creation haha...
Matt M, PA
08-08-2016 06:01 AM
Country_Mouse
01-17-2016 11:53 AM
nagetech
08-23-2015 10:25 PM
Fuzzleak
06-09-2006 02:53 PM
jluttrell
09-13-2004 02:06 PM
Quick Reply: how to remove 3rd row Speaker
