Decode Help for a Dana Axle
Old 03-18-2009, 07:15 AM
addixionz's Avatar
addixionz
addixionz is offline
I have the number of my Dana 60, will someone please decode it for me?
Thanks in advance.
611337-1BA
3231
Old 03-18-2009, 08:55 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Thanks in advance. 611337-1BA 3231
It would help if you listed the year, the series, whether a front or a rear axle.
61XXX-X usually refers to a front driving axle, but...
1964/89: There is no Dana ID number beginning with 611 for a Bronco or F Series truck.
Are you sure 611 is correct and it's not 610?
Old 03-18-2009, 08:45 PM
addixionz's Avatar
addixionz
My bad. I not positive about all the details on the axle. It was on my rig when I bought it. The past owner said it came from a 1999 F350 superduty. 4X4 front axle, and the lug pattern is 8x6.5. I don't remember what year Ford changed to the 8x170 pattern. I will double check the numbers in the morning when I get home from the horse sale. Thanks for the help
Old 03-19-2009, 01:32 AM
NumberDummy
611337-1BA
This Dana ID number is not listed in the 1990/2002 Ford Truck Parts Catalog.
Ford went to the metric bolt pattern in 1999 for F Series trucks.
I'm also suspicious of the Dana's ID suffix of 1BA.
I've never seen a Dana axle installed in a Ford product with that one number, two letter suffix.
With Ford, the suffix is composed of one or two numbers, like this for example: 610010-1 or 610010-11.
There's a Dana website where you can run it down.
Old 03-30-2009, 10:02 AM
addixionz's Avatar
addixionz
Thanks for the replies everyone. I finally got some time off work and cleaned the axle up and found a partial piece of the tag. Also on the center is the the cast number 248, 248mm = 9.76 inches. The dana 60's gear is 9.75 right?
The axle was made Aug. 19 2003 which should make it a 2004 model.
Part number on the tag is 611337-1 on the label. On the long tube the number eched into the metal is 611337-1BA. The pic did not come out as clear as I hoped.
On the front of the cover are the following numbers (look at the pics): 47707-1
211 03
The spacing is 8x170. I thought it was 8x6.5 but when I got the wheel off I found a spacer that converted it to the 8x6.5
Tell me what you think.
Old 08-31-2019, 11:17 PM
ccald727's Avatar
ccald727
ccald727 is offline
611337-1BA
Ford went to the metric bolt pattern in 1997 for F Series trucks, so it cannot be from a 1999 anything.
I have a 2006 e350 and cannot decifer what kind of axle I have. The BOM reads that it is a 3.73 gear and the only number I ca see are 607026-2....i need to find out if it is a dana 60 or 70...do you have an idea?
Thanks
Old 09-01-2019, 03:11 AM
NumberDummy
Originally Posted by ccald727
I have a 2006 E350 and cannot decifer what kind of axle I have. The BOM reads that it is a 3.73 gear and the only number I ca see are 607026-2....i need to find out if it is a dana 60 or 70...do you have an idea?
Please ask questions in the 1968/2013 Full Size Vans (Econoline) forum, this forum is for 1973/79 F100 and larger series trucks.
I cannot help you, I don't have a Ford truck parts catalog after 2001.
Old 09-02-2019, 04:29 AM
fast68's Avatar
fast68
fast68 is offline
arent all dana 60 and 70 10.5" ring gear? on the outside of the center housing in webbing area near axle tube hole is gonna be a very obvious and larger
raised 60 or 70 cast on the center housing webbing area
Old 09-02-2019, 07:54 AM
fordrealdrive's Avatar
fordrealdrive
fordrealdrive is offline
Deleted...
Katmandu
11-21-2008 07:07 PM
78fordf150ranger
11-11-2006 08:30 PM
packnrat
01-24-2005 10:56 PM
rmagoo
09-23-2003 10:09 PM
cies_69truck
11-12-2002 08:05 PM
Quick Reply: Decode Help for a Dana Axle
