factory subwoofer??
Old 01-08-2009, 10:02 PM
SteveVFX4's Avatar
SteveVFX4
SteveVFX4 is offline
as I already stated earlier, no pops from my sub/amp (with speaker level inputs) when turning off and on.
Old 01-09-2009, 12:55 AM
deisele75's Avatar
deisele75
deisele75 is offline
I never had pops from mine either. But i do like RCA inputs better though.
Old 01-16-2009, 08:36 PM
keisha9's Avatar
keisha9
keisha9 is offline
my audiophile bumps pretty good mids tweets and bass , why do u guys need anything ellse try to find a sudiophile setup!
Old 01-16-2009, 10:14 PM
SteveVFX4's Avatar
SteveVFX4
Originally Posted by keisha9
why do u guys need anything ellse try to find a audiophile setup!
because not all of us have the wiring harness under the rear seat in order to plug the sub/amp in! It's not pre-wired for all trucks. Mainly just people with Lariats were able to find the harness plug under the rear seat if they didn't have audiophile to begin with.
So why try to custom wire splice the audiophile sub amp to work when an aftermarket setup would be easier to do.
Old 01-16-2009, 10:16 PM
deisele75's Avatar
deisele75
Aftermarket is way better than audiophile.
Old 01-16-2009, 10:24 PM
johnnycool's Avatar
johnnycool
johnnycool is offline
If you use the lines leavels or the RCA converters, You use the sourse from the rear speakers, yes? do you lose the sound from the speaker you tap? or does it power decrease? Also for a single sub, do you tap both rears? and what is the wire colors?
Old 01-16-2009, 11:06 PM
SteveVFX4's Avatar
SteveVFX4
I tapped into the rear speaker wires and the speakers still play just fine. I can't remember for sure on my amp, but I think I tapped into both right and left speakers even though I'm using a single sub. Probably better to have a balanced input by tapping into both right and left wires.
wire colors are listed at the bottom of this article:
Speaker Replacement Instructions
Old 01-17-2009, 07:18 AM
96sherm's Avatar
96sherm
96sherm is offline
ditto. you can customize a system to perform way beyond a factory unit!!!
fprodget
1997-2006 Expedition & Navigator
09-18-2023 10:33 PM
rickrackleyjr
07-04-2016 09:02 PM
naviGator02
12-17-2015 08:59 AM
pk3550
2004 - 2008 F150
31
07-25-2006 11:45 AM
waircon
07-14-2005 06:37 AM
Quick Reply: factory subwoofer??
