Navigator factory subwoofer enclosure
You need a subwoofer that is optimized for small enclosures. Most likely, it will have to be a sealed enclosures, ported enclosures usually requires bigger volumes. In worst case where you use a subwoofer that is optimized for larger volumes and put it in a ported small enclosure it'll sound worse than the factory unit.
The replacement subwoofer is a Kicker compR which says minimum sealed enclosure is .5 cubic feet,I took a dremel and cut out that cone with the hole in the back of the box and fiberglassed a patch in to make the box air tight. I'm leaning towards ditching the box entirely..just sucks i wasted 70 bucks trying to make it work. (Sound deadener,fiberglass)
BigBadBob
05-28-2007 12:29 PM
