Alarm problem
Alarm problem
Since I got the truck, it was a simple matter of hitting the fob button and the alarm is set. Now, I can't get the alarm to set. The doors will lock, but the alarm, nada! Is there a way to reset the alarm so it'll work like it's supposed to?
Almost forgot, it's possible that my daughter accidentally turned off the alarm, but neither one of us knows for sure.
According to the Ford Dealer, it's the standard Ford alarm with the fob that has three buttons. One to lock, another to unlock, and a panic button.
It looks a lot like this one:
You said it may be in valet mode. I noticed the flashing light is on all the time. I'm thinking you may have something there. How do you return it to the normal mode?
There is no standard Ford alarm. There was an optional dealer installed alarm, but it's actually an aftermarket alarm with Ford badges on it (Codealarm I think). If you didn't pay extra to have an alarm installed by the dealer you don't have an alarm.
Are you sure you weren't just hearing the door lock confimation? If you hit the lock button twice your horn should chirp to confirm that you have locked the doors and they are all shut. If one of your doors is open when you do this it will chirp more than once (three times I think) to let you know that the doors are locked, but one of them is open. Many people think that this horn chirp when you hit the lock button twice is an alarm, but it isn't.
Ok, that does sound like an alarm, it was probably the dealer installed one if you are using the regular Ford keyfob.
Sounds like there may be an issue with the alarm itself. You wil need to find the alarm brain box and try to figure out what you have. Start looking under the dash on thr drivers side for a black box with a bunch of wires going to it.
