Bad knock. Stranded on side of interstate
JUst got my chip back and was testing it out. Was cruising at 55 and got into it a little. And it started tapping knocking like it didnt have oil. so i back out and it got worse so i pulled over. by that time it was shaking and knocking bad blowing white/black smoke to hi heaven. Couldnt se out of cab. Checked oil and coolent both are rith where they should be and exhaust smells like rawl fuel. Thinking maybe rod or stuck injector but was only at like 800* and maybe 10* boost.
Any ideas. I need to get it at least off the side of the interstate and really want to have it to move back home from school on wednesday.
No warnign lights. Pulled the chip out and when tried to start hit a hard spot so didnt crank any more didnt want to tear more up. Gonna try and get a scanner today or tomorrow and see if any codes come up
Another wag might be a bent push rod or a broken rocker ...
Neil- i have an auto. No cel and i think it will start but it hit a hard spot and didnt want to taek chance of tearing more up if it was hydrolocked or bent stuff. motor surges 1-200 rpm and bucks real bad for 10 sec or so than goes away for a while. Only did it btw 40-60 or so so i figured prob issue with the tunes
Thats an idea about rocker or push rod. When i changed the injectors one rocker seemed like it might have been twisted a little. My socket stuck on it when tightened hold down bolts
Action- the tank i was running on is full just filled up last night
Just got it off the road and back to the dairy barns on campus. What an event. Whole time its freezing raining. Called around all day and finally got a trailer so we head out. WHen we got there we realized we forgot come along to pull it up. So i called my boss whose 5miles down the road to see if he has a push bar. SCORE! he has one so go to get it but the truck we went to take someone shut off and it had a bad battery. Now we have a truck and trailer thats almost out of fuel and 2 pick ups that wont run. great. So we call ahaid to the one of the brothers at the house to bring out cables. 20 min later we have truck running and gett the push bar.
From that point things went smooth. Pushed my truck on with a F150 and strapped her down. This is when the state trooper showed up. Figures he gets there when were all but done and not when had battery issues.
Once i finished strapping it down we went 3 miles back to the farm to drop it till i get time to look at it. Took two and a half hrs not bad for all the problems we had and im just happy no one got hit or anything else broke. Only damage was lollipop light cover popped off when bar came under bumper casue the truck and tractor went different direction. Smacked it back on land liek new again. If only the motor was as easy as the light.
no its still here in state college at the university dairy. I might ty to pull it apart this weekend if I can score a shop. I almost started it to pull on trailer and decided ide just take the time and not be sorry.
What should i look for when i get the covers off?
If i cant get it going here one of the brothers lives about an hour north of me and said he could bring a trailer up sat when he comes back up to campus and haul me home if worse comes to worse
