2007 Explorer fuel filter location?
Old 11-26-2008, 07:49 AM
kenneBF250V10's Avatar
kenneBF250V10
kenneBF250V10 is offline
Does anyone know where it is? I did a search on here and came up empty. I haven't physically looked for it on the vehicle yet. I'll be changing oil this weekend and I'd like to change the fuel filter while I'm at it.
Almost forgot, it has the 4.6L V8.
Old 11-26-2008, 12:42 PM
kenneBF250V10
So no one has changed the fuel filter.
Old 08-31-2009, 09:23 PM
spikedog's Avatar
spikedog
spikedog is offline
OK, I'm in the same boat. 2006 Explorer, 4.6L V8, and I've looked on both frame rails, up and down, and I'm completely missing it. I bought a Napa gold filter, it's fairly sizable, Ford can't have hidden it that well, dambit. I seached this forum diligently, and don't tell me "just follow the fuel line." Where is the little pot-licker?
Old 08-31-2009, 11:44 PM
Steina's Avatar
Steina
Steina is offline
CO River Rat
If it's like mine it's in front of the gas tank, behind a shield held on by 2 fasteners. You'll need the tool for disconnecting fuel lines.
Steve
Old 09-01-2009, 08:53 AM
spikedog's Avatar
spikedog
spikedog is offline
I saw that reply on another thread dealing with a 2002 Explorer. The only shield I could see with 2 fasteners was the one where my floor jack was positioned to lift the rig. The two bolts looked like they went right into the frame under the front of the passenger front door - could it be that one?
Old 09-08-2009, 08:32 AM
spikedog's Avatar
spikedog
spikedog is offline
I got the fuel filter changed this weekend. What a PITA! First remove 3 13mm bolts to get a heat shield off, then 2 more 10mm nuts come off to remove a plastic shield. Then, and only then, does the filter show it's ugly face. There is a plate attached to the frame under the passenger door side that has 2 bolts in it, but the plate is tack welded to a crossmember so it's always in the way. I didn't need the fuel filter tool (looks like goofy scissors), just my fingers. One end has a C clip and the inlet side has a red clamp that is tough to figure out. I had to go to Serious Explorations - a dedicated Explorer/Ranger site - to get a decent idea of how to get at this. It was a permanent sticky on their site.
This is obviously an attempt to make everyone head to the dealer to get this filter changed. Absolutely stupid.
Old 10-31-2016, 12:35 PM
spikedog's Avatar
spikedog
spikedog is offline
Just did this filter again at 126K miles
And it's still a PITA. You can watch all the internet videos you want, but they always have the Explorer on a lift. When you are under the car in your driveway, all you can get is one hand up in there. The green clip is fine, it's the red one that is just plain evil. And everything is sharp in there, lots of heat shields and sheet metal.
Old 10-20-2019, 01:40 PM
Luis Figueroa's Avatar
Luis Figueroa
Luis Figueroa is offline
Fuel filter location
How to replace my fuel filter.
Old 10-21-2019, 01:10 PM
shorod's Avatar
shorod
shorod is offline
Welcome to the forum! Did you read the posts above yours that provide some insight in to the filter location and process to change it? What year is your Explorer and which engine does it have?
-Rod
Old 10-21-2019, 02:44 PM
spikedog's Avatar
spikedog
spikedog is offline
I see a first time poster there, Rod. I'll help if I'm able, just waiting for a valid question.
99SuperDuty2017
2017+ Super Duty
01-28-2018 03:07 PM
wglogg
09-12-2016 10:37 PM
panteramatt
06-13-2016 07:06 AM
TallPaul
06-09-2016 03:18 PM
EpicCowlick
6.7L Power Stroke Diesel
58
04-25-2016 01:22 PM
Quick Reply: 2007 Explorer fuel filter location?
