removing 48 ford f1 steering wheel?
I used a 12" long by 1" diameter piece of wooden dowell and a small sledge on my 48 F1. Left the nut loosely on the shaft, placed the dowell on the nut and tapped the dowell with the hammer. While a family member did the tapping, I pulled on the wheel until I got it rocking and finally off. Gearbox wasn't damaged and the no problems with the nut.
Steering wheelremoval
Stevo: You can always break the inner plastic away and cut the prongs with a grinder. Then you can weld the prongs to a washer and use the steering wheel to wheel in and out of the garage to work on it. Thats what I did and doing now. Then heat the lug with a torch and it will tap off. Ralph
Steering wheel removal
Stevo;
If your steering wheel is original you can break the black plastic away from the area around the large nut that holds the wheel onto the shaft. There are two of them, one on each side. They are just prongs made of about 5/16" steel rod. Cut these and remove the wheel. Then heat the sleeve and tap off. This metal sleeve, with gears, is what hods the wheel to the shaft. Hope this helps. Sorry I can't send pictures. Its beyond my expertise.
highoctane74
10-14-2016 08:47 AM
