4.6L V8 skipping under load
I've have a 2000 F150 4.6L V8 (standard transmission) with 40,000 miles - the engine has started to skip while under load. The skip is not consistent . . . just now and then while the engine is under a load / at lower rpm. It "seems" to occur more when the engine is warmed up. I brought it to a shop and the checked for error codes on the computer but they did not find any codes, nor has the check engine light has come on. Just a random skip.
Bad coil ? bad plugs ? Only 40K of light use. I asked on the coils as the shop made reference to replacing a number of coils on a Expedition recently.
Any ideas ? any known problems with the 4.6's skipping ?
Thanks in advance ?
Thanks in advance ?
