4.6L V8 skipping under load
Old 10-31-2008, 12:20 PM
cutterjohn's Avatar
cutterjohn
cutterjohn is offline
I've have a 2000 F150 4.6L V8 (standard transmission) with 40,000 miles - the engine has started to skip while under load. The skip is not consistent . . . just now and then while the engine is under a load / at lower rpm. It "seems" to occur more when the engine is warmed up. I brought it to a shop and the checked for error codes on the computer but they did not find any codes, nor has the check engine light has come on. Just a random skip.
Bad coil ? bad plugs ? Only 40K of light use. I asked on the coils as the shop made reference to replacing a number of coils on a Expedition recently.
Any ideas ? any known problems with the 4.6's skipping ?
Thanks in advance ?
Old 10-31-2008, 10:32 PM
Help_Me!'s Avatar
Help_Me!
Help_Me! is offline
Don't use bosch plugs, if you have them in there. That will cause that type of problem, even if they're brand new.
Old 11-02-2008, 09:09 PM
fordmerc's Avatar
fordmerc
fordmerc is offline
Drive it until the ck engine light comes on and then ck the code. replace the coil and plug on that cyl.
Old 11-07-2008, 05:22 AM
debedwell's Avatar
debedwell
debedwell is offline
My 97 with the 4.6 did that on Weds took it to shop and found the spark plug wires where arcing and needed replaced, Runs better then ever now.
Hope that helps
francissmith14
Modular V8 (4.6L, 5.4L)
09-27-2014 07:45 AM
dfac69
03-17-2013 09:15 AM
reynolds357
1997-2006 Expedition & Navigator
15
10-07-2010 10:02 PM
SteevenH
1997 - 2003 F150
13
02-26-2010 03:47 AM
cutterjohn
1997 - 2003 F150
01-25-2004 11:15 AM
Quick Reply: 4.6L V8 skipping under load
