Does anyone know where to get a replacement, aftermarket intake tube that goes from the trubo to the air filter? Mine is cracked where the hose clamp goes at the turbo.
I'm guessing you still have the original red one. I think you have to get a super duty hose because they stopped making the direct one for the OBS trucks. Its a direct fir though. The only place i found was at the dealer.
NO! The souper dooty hose is NOT a direct fit.
You can get an aftermarket replacement for the discontinued hose here:
when mine went i got the hose coming from the turbo to the elbow where the ccv goes and had to replace the elbow also. They had it listed as a "kit". No mods needed
I'm sure there are cheaper aftermarket options
I have the boot if need it. You will need a piece of 4" exhaust pipe to do the ccv mod. I believe the dealer wants around $50 bucks for it. PM me if you want it.
it eliminates the crankcase vapors from being recirculated to the motor and vents them to atomsphere like a big rig. its not a big deal on a stock truck but when you add an intercooler its nice to have since it eliminates oil in the tubing.
Is that a K&N filter housing that you have the 6637 mounted in? I have the K&N that I want to switch to the 6637 and would like to keep the box if it fits. Also where did you mount the sensor (baro) because it looks like there isn't room for it, kind of tight in there?
