Rubber intake tube
Old 10-13-2008, 10:23 AM
97PWRSTK's Avatar
97PWRSTK
97PWRSTK is offline
Rubber intake tube
Does anyone know where to get a replacement, aftermarket intake tube that goes from the trubo to the air filter? Mine is cracked where the hose clamp goes at the turbo.
Old 10-13-2008, 10:39 AM
wmiller's Avatar
wmiller
wmiller is offline
I'm guessing you still have the original red one. I think you have to get a super duty hose because they stopped making the direct one for the OBS trucks. Its a direct fir though. The only place i found was at the dealer.
Old 10-13-2008, 10:45 AM
kawa's Avatar
kawa
kawa is offline
Check with C00nhunterjoe, he seems to have that info.
Rog
Old 10-13-2008, 10:55 AM
c00nhunterjoe's Avatar
c00nhunterjoe
c00nhunterjoe is offline
i try junkyards or ford, the junkyard is definatly cheaper
Old 10-13-2008, 11:17 AM
BlueMule's Avatar
BlueMule
BlueMule is offline
NO! The souper dooty hose is NOT a direct fit.
You can get an aftermarket replacement for the discontinued hose here:
http://intakehoses.com/Merchant2/mer...egory_Code=FPM
Old 10-13-2008, 11:18 AM
c00nhunterjoe
i put the superduty tube and ccv adapter on my truck with no issues.......
Old 10-13-2008, 01:37 PM
wmiller's Avatar
wmiller
wmiller is offline
when mine went i got the hose coming from the turbo to the elbow where the ccv goes and had to replace the elbow also. They had it listed as a "kit". No mods needed
I'm sure there are cheaper aftermarket options
Old 10-13-2008, 02:05 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Silicone 45 Degree Reducing Elbow 3-3/8" to 3" 1820102C2: Intake Hoses, IntakeTubing, and Intake Clamps
X2 what he said about tha SD hose; and the hose from intakehoses is a direct fit.
In that way (with tha adapter) it works well with the SD tube., or better you can do the CCV in that moment.
Old 10-13-2008, 02:15 PM
c00nhunterjoe
you mean like this?
Old 10-13-2008, 02:24 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
you mean like this?
yeap or lik this one:
Old 10-13-2008, 03:02 PM
Neal 97 250's Avatar
Neal 97 250
Neal 97 250 is offline
I have the boot if need it. You will need a piece of 4" exhaust pipe to do the ccv mod. I believe the dealer wants around $50 bucks for it. PM me if you want it.
Old 10-13-2008, 07:17 PM
97PWRSTK's Avatar
97PWRSTK
97PWRSTK is offline
Thanks guys, I found one at a salvage yard. What is the ccv mod you guys talk about?
Old 10-13-2008, 07:55 PM
c00nhunterjoe
it eliminates the crankcase vapors from being recirculated to the motor and vents them to atomsphere like a big rig. its not a big deal on a stock truck but when you add an intercooler its nice to have since it eliminates oil in the tubing.
Old 10-13-2008, 07:59 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Check this link:
Welcome to guzzle's CCV mod web page
Old 10-16-2008, 05:38 PM
GWF3507.3's Avatar
GWF3507.3
GWF3507.3 is offline
Hey Roentgeep,
Is that a K&N filter housing that you have the 6637 mounted in? I have the K&N that I want to switch to the 6637 and would like to keep the box if it fits. Also where did you mount the sensor (baro) because it looks like there isn't room for it, kind of tight in there?
Quick Reply: Rubber intake tube
