Compression guage
Compression guage
Hey guys I was just curious how to use a compression guage. I need to check one cylinder out in my 460. Its missing an am trying to determine the problem. I need to be educated here on how to use it. I am not for sure if this is the right forum but i thought I would post it here to see. Hopefully somebody will reply with some info. Any tips or suggestion would be much appreciated. What should the lbs read for each cylinder. A quick response would really be helpful as i need to do this as quick as possible. If I have any other questions i will let you know. Thanks.
First, you never just check one cylinder (well I have but I checked the compression before and after every race, so if a plug looked bad I would check just one, but street motors are different). You need to compare the highest compression number to the lowest. A 15% difference between high and low is all that is acceptable. Now remove all plugs, lock the throttle Wide Open. Screw in compression gauge in and crank engine about 5 to 10 times, or until the the needle stops bouncing. Record number and then go through all the rest of the cylinder. Now check your numbers.
Used to race up until 1994. First I raced cars, Ford from my 1956 Crown Victoria thru my several 428CJs. The I switched over to boats, the 2 stroke kind.
This
with this
Then this one
several others then lastly this one.
This
with this
Then this one
TexasMarkIII
07-30-2013 12:28 PM
hugger94
09-17-2012 08:16 PM
Johnblagg
10-14-2010 04:17 PM
Furyus1
18
07-05-2009 09:32 PM
